COOLANT CHANGE??
Old Jan 11, 2006 | 11:28 PM
COSSIE 1's Avatar
COSSIE 1
Default COOLANT CHANGE??
Im going to give my erst a coolant change soon, its something ive never done always taken to garages etc, i know u empty old water out, then im going to put a hose in the radiator and give it a good flush, then reconnect the hoses etc and put all the right antifreze mix in etc, whats the best way to bleed the system??, do u put the heaters on hot etc .........any more tips cheers all......p.p
Old Jan 12, 2006 | 12:17 AM
rst230bhp's Avatar
rst230bhp
As far as im aware the only way to bleed the air is to leave car running from cold with the header tank cap off and once the fan cuts in give the coolant hoses a few squeezes, you should see loads of air bubbles coming out.
im sure somebody else will correct me if im wrong
Old Jan 12, 2006 | 12:27 AM
COSSIE 1's Avatar
COSSIE 1
got a bit puzzled when i coudnt find a bleed screw , so that sounds pretty straight forward
Old Jan 12, 2006 | 12:37 AM
SafeChav's Avatar
SafeChav
As above, literaly fill the bottle up, it will take a while to fill up the system, once its stopped going down fill it to the maximum mark, then start the car, and allow it to run up to temperature (u can flick the blowers on if u want, put them on low though, as it all affects warm up time), top the coolant up as/when it starts to go down, i personally get the cap on just before the fan is about to cut in as otherwise the expansion bottle usually overflows because its so close to boiling point, but it should be as simple as that. Once the fan has turned back off all the hoses should be good and hot, likewise so should the heaters.
Old Jan 12, 2006 | 01:15 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
i usually take the hose off the top of the thermoustat housing to and it'll let some air escape, then when it piss's water stick it bk on, with the h.cap off, then as everyone sais when it's hot stick the cap back on!
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
