how do u fit a pace double capacity intercooler to a s2 rst?
Hello people, i need some help!, ive just bought a second hand pace double capacity intercooler but it came without fitting instructions. have any of u lot fitted one? if so hows it done? im guessing the fan and rad need to be moved?
any help would be great thanks!
You should have three brackets. One plate with a spindle (top rad locating bracket. One F shaped bracket (locating the bottom of the rad). And one straight thin plate (for moving the fan over).
evening bud , i may be wrong but im sure either last months or this months fast ford did an article on fitting a fmic , now it may not be the same companys but im certain they will be the same as in fitting ??
alternatively u could e mail the manufacturers of it and explain ur predicament , doubt ull have anyone here expalin it has u could probbably do with pictures to clarify the instructions
hope this helps
bri
hope this helps
bri
just realised why i cant work it out, im one fucking bracket short(the longest one)
another ebay horror story!!!!!!!!!!!!!!!!
many thanks for all your help, im going to ring pace tommorow to see if they will supply with one.
another ebay horror story!!!!!!!!!!!!!!!!many thanks for all your help, im going to ring pace tommorow to see if they will supply with one.
Billy_RS
16
Oct 11, 2025 09:41 PM
