misty inside
Old Jan 11, 2006 | 05:18 PM
RST Ski's Avatar
RST Ski
Default misty inside
does any1 else's rst mist up inside the car when it rains??
Old Jan 11, 2006 | 05:37 PM
Would suggest the car is getting damp, did some work on a friends car a few weeks back that this happened on ,turned out to be some minor holes in the footwells ,car does not mist up now .
Old Jan 11, 2006 | 05:42 PM
SafeChav's Avatar
SafeChav
Sorry completely off topic but rs tommy your Avatar is quality
Hint hint nudge nudge
Old Jan 11, 2006 | 06:52 PM
RST Ski's Avatar
RST Ski
Old Jan 11, 2006 | 06:54 PM
RST Ski's Avatar
RST Ski
whats the most common places for water leaks and holes to occur?
checked under me battery tray and thats ok
Old Jan 11, 2006 | 07:16 PM
SafeChav's Avatar
SafeChav
check the sunroof drainage tubes arent blocked, and you might find the inner sun roof tray is rotten/got rust holes in it.
Bottom of the windscreen seal too, the scuttle panels tend to rot
Old Jan 11, 2006 | 07:38 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
worth keepin a eye on your coolant level, it could been seeping out of the matrix
water can get in loads of places, inner arch/ floor, battery tray even it if looks ok check from under dash behind the sound proofing, fuse box, or just feel about on the floor will feel if its wet , if its just water off ya boots get some mats
Old Jan 11, 2006 | 07:56 PM
SafeChav's Avatar
SafeChav
The dreaded leaky matrix
IS your car behaving now by the way
Old Jan 11, 2006 | 08:04 PM
1.9 xr2 on 40's
st170 breaking
hmmm yeah pretty much, keeps holding back when i get to about a ton and most of the way up at some time or another, not that i know now cos the speedo cable bust today and replaced 90 spec clocks with 88 and nuffin worked so im back to the 90 spec again *now i know thwy are NOT interchangable, tryed it today with 2 ests of clocks neither worked as they shud*
shes gettin faster and better tho, stripped more off my yella turbo today so garadually sorting the lost bolts etc etc i am missing my bigger turbo tho
maybe soon ill fit a rear mount to the gearbox propperly
needs to have quite a bit done but ill strip it and scrap it before i get round to it all
bought meself a long crack bar today too so i can play driveshafts without a scaffy pole of a ratchet
Old Jan 11, 2006 | 08:49 PM
Danny boy's Avatar
Danny boy
yeah was a minor repair that !!!
Old Jan 12, 2006 | 05:07 PM
RST Ski's Avatar
RST Ski
dash out for heater matrix? id better check, wheres its located?
Old Jan 12, 2006 | 05:10 PM
1.9 xr2 on 40's
st170 breaking
dash out is easier if it were me (it was last week )
but it can be removed by only takin the soft part off on the pass side, maybe even squeesed out with it in but dashes come out easy
Old Jan 12, 2006 | 05:31 PM
RST Ski's Avatar
RST Ski
Forgot to say, its only ever the front screen that mists up
Old Jan 12, 2006 | 05:34 PM
SafeChav's Avatar
SafeChav
could be your heater matrix weaping very slightly, do u lose any coolant at all?
Old Jan 12, 2006 | 05:41 PM
SafeChav's Avatar
SafeChav
Ive got a torque wrench thats only about 2 foot long and i can undo drive shafts a piece of piss with that, u must be a wimp
Did a CV gaitor a few months back on my orion (can u believe it had the original CV gaitor on it for 20 years and the driveshaft had NEVER been out, spotless just pushed out, no rust at all )
Heater matrix i believe can just about be done with dash in, bit of a slag though.
Old Jan 12, 2006 | 05:59 PM
1.9 xr2 on 40's
st170 breaking
my crack bar is 2 foot long
the ratchet i usually use is only bout 8- 10"
Old Jan 12, 2006 | 06:42 PM
SafeChav's Avatar
SafeChav
Well thats fine then
(are you sure your interpretation of 2 foot is the same as my 2 foot )
Old Jan 12, 2006 | 07:55 PM
1.9 xr2 on 40's
st170 breaking
yup the ladies love my foot long
Old Jan 12, 2006 | 07:56 PM
SafeChav's Avatar
SafeChav
So its only a foot now then
Old Jan 12, 2006 | 07:57 PM
1.9 xr2 on 40's
st170 breaking
i wasnt talklin bout the bar this time
Old Jan 12, 2006 | 07:59 PM
SafeChav's Avatar
SafeChav
Old Jan 13, 2006 | 04:46 PM
RST Ski's Avatar
RST Ski
not sure, cars at the bodyshop, have to check when its out
155lee
Sep 6, 2016 11:10 AM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
hopper350
Sep 4, 2015 12:53 AM
