Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
Fiesta RST Sensors needed
Old Jan 9, 2006 | 11:32 PM
mathewwebber's Avatar
mathewwebber
Default Fiesta RST Sensors needed
I have been chatting to Matt Lewis about the problems i have been having, as MLD built the engine in mine.
He has suggested id try changing the ECT sensor (on back of inlet) as well as the TPS and Fuel pressure Regulator. The car is running a fiesta engine with OFAC management if that makes a difference
Does anyone have a good set of these i could buy? Must be GWO obviously as i need to rule bits out where possible.
Mat
Old Jan 10, 2006 | 09:49 AM
jonnyturbo's Avatar
jonnyturbo
i have the full inlet setup off a frst, sitting in the garage, not sure what the sensors are that you need but if you pm me with basic instructions of where they are located, i have the full fuel rail and injectors all still bolted onto plenum, also have the fpr. the car was an ofac too.
Billy_RS
16
Oct 11, 2025 09:41 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
col93saphcos
Aug 7, 2015 03:21 PM
dlwarrior
Aug 5, 2015 10:19 AM
