ROOF RUST
How many of u guys with s2 erst have got/had rust on the roof behind the sunroof? ive got 2 little bits about 5mm big and 2 bis about 2mm big, i know if i was to get the work done it would be alot worse under the paint
but how much have people paid/where to get the work done? cheers peeps
I had it on mine,didnt bother getting it fixed,just scraped the shell.This rusty roof will cost you big ££££££££'s to be fixed correctly.Give Moorland a ring,they are recomended by Castle Performance.Regards Micky
GOING TO BEST PART OF A £1000 MATE BETTER OF PUTTING NEW ROOF ON OTHER WISE MEANS CUTTING ALL RUST OUT AND REPLACING WHICH IS A CUNT AS THE ROOF WARPS WHEN YA MIG IT UP IT QUITE A FUCK ON,BUT WANTS DOING PROPERLY AS IT WILL JUST KEEP COMING BACK
i did this myself on my last escort
, but a thing well worth noticing is that you cant do more than 1 spot weld at a time.. 1 spot and wait for about 3 minutes, then do another.. if you do it much faster than this it will warp.. a mate of mine had a real shitter with rust in the roof for a while so we tried to weld his roof before we did mine so we learned a couple of things on that project..
but as long as it gets too cool properly it's not a problem..
