CLUTCH SLIP
JUST FITTED A STANDARD FORD CLUTCH TO A SERIES1 AND IT SLIPS IN 4TH / 5TH CAR HAS BEEN SLIGHTLY MODIFIED BUT NOT SURE AS YET TO WHAT DEGREE HAS ANYDODY EVER COME ACROSS THIS
OWNER HAS TURNED DOWN BLEED VALVE WHICH HAS STOPPED SLIP BUT NOW CAR FEELS SLOW
NOT SURE WHAT BOOST ITS RUNNING YET ANY IDEAS?
THANKS GUYS
THANKS GUYS
funny enough you should say this. My clutch was slipping at 12psi with a new ford clutch turned the boost down to 9psi and it was fine slowly over the last couple of months ive been slowly winding it back up and now im running 15psi with no problem wierd
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
