ggr header tanks
Old Jan 6, 2006 | 09:22 PM
THE RADMAN's Avatar
THE RADMAN
Default ggr header tanks
on the alloy water tanks that ggr do,there is a pressure valve fitted to the top right connection,like a tyre valve, why?
Old Jan 6, 2006 | 09:31 PM
Damo V's Avatar
Damo V
Not really a necessity on a road car, but on the rally cars, If they depressurised the coolant during "service" they would re-pressurise to keep temps down as quick as poss before heading off
ballin's Avatar
ballin
oops read that wrong!
Old Jan 6, 2006 | 09:43 PM
THE RADMAN's Avatar
THE RADMAN
good one damo
Old Jan 6, 2006 | 09:49 PM
wayneclayden's Avatar
wayneclayden
590 BHP/Ton
Higher pressure raises the temperature that the water boils at.... some systems have a schreader valve to pressurise the system..
Old Jan 6, 2006 | 10:00 PM
Damo V's Avatar
Damo V
Which is what he asked about
Old Jan 7, 2006 | 07:32 AM
wayneclayden
590 BHP/Ton
nearly!
the pressurisation does not reduce the temp- it just stops the water from actually boiling.
Old Jan 7, 2006 | 07:56 AM
ian sibbert's Avatar
ian sibbert
the systems are pressurised to 2 bar all the time....to increase boiling point.....
Old Jan 7, 2006 | 09:22 AM
Ginge !'s Avatar
Ginge !
just finding my feet
what is the benifit of higher water temps as all the newer cars have higher boiling points these days
Old Jan 7, 2006 | 11:00 AM
wayneclayden
590 BHP/Ton
Originally Posted by b19bal
what is the benefit of higher water temps as all the newer cars have higher boiling points these days
there is no benefit to higher water temps- you would only use this system in a situation where you can not cool the water down sufficiently.
Pressurising the system will allow you to run at say 115 degrees C without the water boiling and spitting out everywhere...
Old Jan 7, 2006 | 04:42 PM
Damo V's Avatar
Damo V
nearly!
You know what I meant
Nov 1, 2015 06:53 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
