wilwood calipers
hello all
i have a set of wilwood dynalite 4pot calipers on my s2, the calipers have seized, anyone know if i can get them rebuilt and how much it is likely to cost me. or am i better of buying new calipers.
also has anyone done the st170 brake conversion would they be better than what i ahave at the moment.
pls help
pls help
Can't comment on the Wilwoods but would suggest contacting Wilwood directly to see if they can refurb/service your callipers.
The ST170 conversion works a treat. Only brakes I've had where I haven't buggered them in no time. Although I have warped a set of the 300mm discs
(had a few setups as well)
cheers for the replies guys
not too sure my mechanic advised their seized so im assuming its the pistons
Oranoco if you dont mind can i ask how much you paid for the st170 set and wheres the best place to sorce all parts required.
thanks
Is it the pistons thats actually siezed
thanks
