Help Eagle con rods
Old Jan 5, 2006 | 12:55 PM
JamesS2RS's Avatar
JamesS2RS
Default Help Eagle con rods
Will these work on a 2.0 zetec block for my zvh ?
http://www.newedgeperformance.com/in...PROD&ProdID=43
http://www.eaglerod.com/products/For...yl%20rods.html
Any help would be good.
Jim
Old Jan 5, 2006 | 04:23 PM
Badman38's Avatar
Badman38
Default Re: Help Eagle con rods
Jim
yes these are what i am currently using in my zvh with je pistons
Old Jan 5, 2006 | 04:43 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Yes, ONLY if you use FOCUS type pisons with them! (Ie, from the states).
If you use "UK" mondeo type pistons, you'll run into all kinds of trouble!
Old Jan 5, 2006 | 04:49 PM
Badman38's Avatar
Badman38
yeah sorry i should of mentioned.. i use je pistons and eagle rods on a sliver top but they are meant for the black top focus engine so i had to use a 1.2mm de-comp plate to reduce the comp ratio from 8:4:1 (57cc cvh head) to 7:8:1
Old Jan 5, 2006 | 07:39 PM
JamesS2RS's Avatar
JamesS2RS
So could i run these rods on calbra pistion machined to the correct CR
Using a cvh head??????
Jim
Old Jan 5, 2006 | 07:43 PM
bassboy's Avatar
bassboy
ive heard these can be weaker than standard rods...not too sure how accurate that info is but it was told by a main dealer of their rods
bassboy
Old Jan 5, 2006 | 07:55 PM
JamesS2RS's Avatar
JamesS2RS
Do u have to run focus pistions or could i run anyother type with these rod ????
Jim
Old Jan 5, 2006 | 08:18 PM
PhilM's Avatar
PhilM
Jim
Noooo! Calibra pistons are for use with Mondeo rods. If you use them with a Focus rod (ie, Eagle), the rod+piston length will be wrong, if memory serves, they will be too long and the piston will be poking out of the block by about 5mm!
If you do decide to try Calibra pistons and Eagle rods, make sure you measure them etc before commiting to buy, but I am sure they are wrong! Use a Focus type piston and then machine to suit the desired CR.
Calibra pistons and a mondeo rod will give about 7.4:1 IIRC with a 16v head.
Old Jan 5, 2006 | 08:24 PM
JamesS2RS's Avatar
JamesS2RS
So as long as i use focus pistons with these rod and machine the focus piston to the correct C R It will be fine with the 2.0 mon zetec??
Jim
Old Jan 5, 2006 | 08:28 PM
PhilM's Avatar
PhilM
Yup
Old Jan 5, 2006 | 08:31 PM
JamesS2RS's Avatar
JamesS2RS
Now one last question What focus pistions should i buy?
Jim.
Old Jan 5, 2006 | 08:38 PM
PhilM's Avatar
PhilM
Can't advise you there really mate!
I know CP pistons do custom jobs though, so may be able to help with a piston with the correct CR and 8v valve cutouts.
Perhaps Ian Howell (Area Six) is worth a call, tell him you want to use Focus Rods, and what pistons can he sort for a ZVH engine (he deals with CP Pistons believe)
Old Jan 5, 2006 | 08:51 PM
JamesS2RS's Avatar
JamesS2RS
Is there a std size i could get machined?
Jim
Old Jan 6, 2006 | 10:08 AM
JamesS2RS's Avatar
JamesS2RS
Phil U the MAN!
Area Six can sort out the pistions
Phil cheers for all your help
Jim
tankybaby66
Feb 6, 2016 02:24 PM
stevecfrst1
Sep 30, 2015 05:18 AM
little bram
Sep 27, 2015 07:45 AM
S3an
Sep 26, 2015 11:39 PM
coscor86
Sep 20, 2015 01:21 PM
