who sells NGK BCR8ES plugs & how much???
Jan 4, 2006 | 10:27 PM
as above im looking for the cheapest place to get a set of
NGK BCR8ES spark plugs
any suggestions
cheers
marc
Jan 5, 2006 | 05:03 AM
Jan 5, 2006 | 07:45 AM
RS & ST Parts Specialists
Do you have the full part number?
Matt
Jan 5, 2006 | 03:08 PM
no sorry mate,,,
see if i can get it tommorow tho
Jan 5, 2006 | 04:29 PM
Jan 5, 2006 | 04:38 PM
Quote:
Originally Posted by Dave McB
ngk bcr8es
cheers fella
Jan 5, 2006 | 04:50 PM
any motor factors should have u a set within a couple hours......last set i got cost me 6 quid iirc (trade price
Jan 5, 2006 | 04:51 PM
£6 from any factors up here m8.
Jan 5, 2006 | 04:53 PM
£1.25 EACH FROM ANYWHERE.
Jan 5, 2006 | 06:21 PM
think i might even have a set in me garage
more than welcome to them
will check for ya in the ron
Jan 5, 2006 | 06:47 PM
are they as good as the motorcraft agpr901c
Jan 5, 2006 | 07:58 PM
not sure
i was recomended the ngk 8's by the company dyno'ing the engine
Jan 5, 2006 | 08:21 PM
Quote:
Originally Posted by M K
not sure
Then you don't want BCR8ES then. That is a normal road plug...
Jan 5, 2006 | 08:28 PM
bcr8es is the sort of plug you buy from the factors for 25p for your nissan micra. you sure they meant BCR8ES?
Jan 5, 2006 | 08:31 PM
It's also the std recomended for the RST - good plug utpo a bar or so
Jan 5, 2006 | 08:56 PM
must be another 1 then,,,,,,,as il be running more than a bar
Jan 5, 2006 | 10:30 PM
It won't be, it will be the 8ES he's recomended.
I would use the AGP071 from ford, and change it every 6k
Jan 5, 2006 | 10:35 PM
you sure its not the NGK PRF8B's
the irridium tipped ones as fitted to stock nissan turbos (albeit in different heat ranges) ?
Jan 5, 2006 | 10:47 PM
as rick says u cant go wroung with 071 plugs
Jan 5, 2006 | 11:14 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flatlinedan
Sep 18, 2015 12:41 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
agpr901c ,
bcr8es ,
buy ,
me6 ,
motorcraft ,
ngk ,
number ,
part ,
plug ,
prf8b ,
sale ,
sells ,
spark ,
uk ,
who
