motorsport parts UPDATED 17.2.06
Old Jan 4, 2006 | 12:26 PM
ATM SPORT's Avatar
ATM SPORT
Default motorsport parts UPDATED 17.2.06
Escort Cosworth Gearbox Parts
Front diff strengthening plate Kit ₤ 65
GPN Centre VC pumped up ₤350 exchange
909 GPN front diff complete 3.6 with plate £ 350
909 GPN rear diff 7 “complete 3.6 £ 400
NEW Rear diff 7.5 plated LSD complete 4.4 ratio £1250 SOLD
Lay shaft for sport gear box (new) £ 850
5th gear for sport box (new) £ 150
4th gear for sport box (new) £ 150
1st gear for sport box (new) £ 150
Twin paddle clutch 1”23 spline complete ₤ 200
Escort GPA Parts
GPA escort bumper pods ₤ 120 pair SOLD
LHD GPA rack new ₤ 950
New Pectel style monitors (just need baby board in ECU) ₤ 400
Set 3 way Proflex Tarmac GPN dampers ₤ 1800 SOLD
Front 50mm works Bilstien damper pair ₤600
New ALS throttle body ₤ 100 SOLD
Pair gravel rear Proflex dampers ₤ 600
Single paddle GPN clutch used ₤ 180 SOLD
Single paddle GPN clutch new ₤ 280
New LHD GPA Clutch cable ₤ 50
New RHD GPA Clutch cable ₤ 65
New escort full length sump guard ₤ 250
Pair alloy front uprights complete ₤ 950 SOLD
Pair alloy TCA ₤ 500 SOLD
Pair steal adj TCA ₤ 300
Pair front GpA shafts std to alloy upright ₤ 500 SOLD
Pair rear GPA shafts ₤ 500
Stainless 3” exhaust system clubman GPA £ 200 SOLD
Alloy front GPA top mounts £ 200 a pair
9” Kevlar rear diff guard £ 75
Alloy rear diff guard £ 55
RS500 style intercooler £ 400 SOLD
Recaro rally seat £150 SOLD
Pair adj comp struts complete £ 300
RS500 8 injector manifold less throttle body and elbow £ 850
Sapphire GPA turbo new £ 450
GPA power steering pump & alloy bracket £ 200
GPA altenator and alloy bracket £ 300
AP rear 285mm brake setup complete £ 550 SOLD
Pair 380mm front discs £ 180
GPA rear beam round £ 350
Escort cosworth Like new front bumper £ 550
Escort cosworth rear bumper £ 200
Pectel T6 ECU £ 1100
.63 Turbo housing £ 150
Steel front GPA cross member £ 400 SOLD
New GPA turbo with 247 £ 1650
2 WD big wing sump £ 280 SOLD
2WD quick rack £ 500
Pectel T3 ECU £ 700
GPA lightened fly wheel £ 150
Mag pedal box £ 450 SOLD
Mag rear arms £ 450 each SOLD
Pectel 8 injector loom £ 350 SOLD
2 WD side exit exhaust £ 200
Alloy toe links £ 300
Pair 355mm front discs £ 180
Escort WRC parts
alloy clutch fork 9096598 £ 45
alloy sump gaurd supports 9096836 £ 80
alloy jacking bars 9095620 /9095621 £ 45
front drive shafts complete 9096264 / 9096702 £ 250
9" rear diff VC case 9094054 £ 100
9" rear diff output flanges 9093250 / 9093251 £ 100
rear stub shafts 9096783 / 9096996 £ 150
MPC alloy pump bracket £ 80
MPC brake valve block £ 200
MPC acumulator block 9097040 £ 250
MPC main valve block 9097075 £ POA
MPC adjuter £ 45
WRC turbo complete £ 1850
WRC side exit exhaust £ 500
batery box 9096773 £ 30
alt air duct heat shield 9095819 £ 25
50mm front gravel damper body 9095003 £ 75
50mm front tarmac damper body 9095642 £ 75
mag sump cover plate 9095552 £ 20
steering arms 9096686 / 9096685 £150
caliper alloy bracket 9096242 £ 45
turbo heat shield 9095767 £ 65
gearbox mount 9094719 £ 65
front prop shaft 9097029 / 9096689 £ 200
rear prop shaft active 9096248 £ 300 SOLD
rear prop hand brake release 9096301 £ 350
tarmac front uprights 9096292 / 9096293 £ 650
steering tarmac 9096144 / 9096145 £ 100
roll center spacers 9096928 / 9096171 £ 35
WRC tag Alternator 9096504 ₤400
WRC 8 injector plenum and rail £ 480
tarmac front hub 9096907 £ 150
gravel front uprights 9097102 £ 450
front wheels bearing 9096436 £ 80
front flange 9097016 £ 150 SOLD
alloy TCA complete 9096679 / 9096493 £ 250
comp struts complete 9096299 £ 150
PAS pump 9095670 £ 250
alloy PAS bracket 9095246 £ 45
alloy alt bracket 9096952 £ 45
alloy hand brake lever 9096421 £ 35
front anti roll bar 9096938 /9096937 £ 150
rear roll bar 9096940 / 9096939 £150 SOLD
roll bar blades 9092233 /9092232 £ 100 SOLD
roll bar drop links 9096544 / 9096336 £ 75 SOLD
roll bar clamps 9094703 £ 55 SOLD
front bumper top half 9096728 £ 150
front bumper air ducts 9096781 £ 60
door mirror 9096103 £ 45
door carbon mirror blank 9095679 £ 15
378mm tarmac brake bells £55
LHD steering rack 9096840 £ 750
RHD steering rack 9094765 £ 750 SOLD
steering yokes 9096192 £ 45
steering rods 9096490 £ 35
TRE 9096162 / 9096163 £ 85
steering upper colmube 9096173 £ 65 SOLD
steering lower colmube 9094616 £ 45 SOLD
steering universal joint upper 9092564 £ 45 SOLD
brake pads £ 60
non,active 9"rear diff not mag 9096018 £ 3000
brake back plates 9095826 / 9095848 £ 45
complete suspention bolt kit £ 35
rear drive shafts complete 9095636 £ 250
rear diff cooler 9095702 £ 10
rear diff cooler brakcet 9096798 £ 12
9" rear diff CWP 4 .4 ratio 9095467 £ 350 SOLD
adaptor starter 9096267 £ 15
light weight starter motor £ 100
turbo exhaust housing 9096985 £ 150
PAS alloy pulley 9096195 £ 45
atenator alloy pulley 9097108 £ 30
crank alloy pulley 9096199 £ 180
Old Jan 4, 2006 | 02:02 PM
wimwerf's Avatar
wimwerf
whats the difference between a group n diff and a standard diff...
Old Jan 4, 2006 | 04:38 PM
Kelv's Avatar
Kelv
Almost there!
was going to ask the same question!
Old Jan 4, 2006 | 04:41 PM
silky16v's Avatar
silky16v
Get on That!
I right in thinking they are Thicker Walled Diff?
Old Jan 5, 2006 | 08:27 AM
ATM SPORT's Avatar
ATM SPORT
hi
the crown wheel and pinion and planet gears are all 909 parts,,
Old Jan 10, 2006 | 08:30 AM
costech's Avatar
costech
Could you post a pic on the mag pedalbox ?
Old Jan 10, 2006 | 12:01 PM
Davey8oy's Avatar
Davey8oy
are the pectel style monitors the collins ones and are they the adjustable too?? cheers
Old Jan 13, 2006 | 10:36 AM
Davey8oy's Avatar
Davey8oy
Old Jan 17, 2006 | 11:13 AM
ATM SPORT's Avatar
ATM SPORT
i don't know the make of them, yes they are ajustable,,
Old Jan 17, 2006 | 05:08 PM
Davey8oy's Avatar
Davey8oy
ATM SPORT
any pics?
cheers fella
Old Jan 18, 2006 | 02:07 PM
ATM SPORT's Avatar
ATM SPORT
Old Jan 22, 2006 | 04:14 PM
James-W's Avatar
James-W
What is a Pectel T3 ECU as I have never heard of one. Are they like the T4 was going to be (a bridge between a T2 and T6)?
Old Jan 23, 2006 | 08:09 AM
ATM SPORT's Avatar
ATM SPORT
T3 was fitted to the puma kit car,, yes it was T6 bady brother
Old Jan 23, 2006 | 04:18 PM
James-W's Avatar
James-W
Cheers mate.
I take it its better than T2.
How much do you sell 4.4 ratio mag 9" rear differentials for?
Old Jan 24, 2006 | 08:44 AM
ATM SPORT's Avatar
ATM SPORT
Cheers mate.
hi
3000 pounds fully rebuilt,,
Old Feb 6, 2006 | 04:42 PM
ATM SPORT's Avatar
ATM SPORT
TOP
Old Feb 17, 2006 | 03:35 PM
ATM SPORT's Avatar
ATM SPORT
TOP
Old Feb 17, 2006 | 04:51 PM
Ryan's Avatar
Ryan
any 2wd front bilstein casing?
Thanks
Ryan
Old Feb 17, 2006 | 10:59 PM
Vic's Avatar
Vic
following up that gated baffle for the 2wd sump...
Old Feb 18, 2006 | 08:12 AM
ATM SPORT's Avatar
ATM SPORT
Thanks
Ryan
we have GPA two bolt fixing ,,,,
Old Feb 18, 2006 | 08:31 AM
Ryan's Avatar
Ryan
thanks anyway andy was after standard fitment
155lee
Sep 6, 2016 11:10 AM
steve.rst
Mar 15, 2016 08:01 AM
dirty-diesel
Oct 3, 2015 08:00 PM
dal3door
Sep 14, 2015 05:34 PM
