battery voltage on idle
Old Jan 4, 2006 | 11:55 AM
JimmyFlo's Avatar
JimmyFlo
Default battery voltage on idle
what is the battery voltage meant to be on idle? mines reading at 12.5 then hits 14 when the revs get to 3000 is this right? i though it was meant to be 14 whenever the engine was running
cheers
Old Jan 4, 2006 | 12:50 PM
AlexF's Avatar
AlexF
new alternator time!
Your right it should read 13-14 volts all the time, depending on how much the battery is being charged
Alex
Old Jan 4, 2006 | 12:53 PM
3drstretch's Avatar
3drstretch
If it's only only initial start up that charges at 12.5 then charges at 14v after hitting 3k it is fine as you not hitting the fast idle setting in alternator but if it charges at 12.5 after the intial revving then new alternator/regulator time.
Old Jan 4, 2006 | 12:56 PM
AlexF's Avatar
AlexF
If it works after you rev the engine to 3k then the field windings are not being powered by the "car". Thats the purpose of the dash warning light
Alex
Old Jan 4, 2006 | 12:59 PM
3drstretch's Avatar
3drstretch
So following on from wot alex says above is battery light working on dash as this must complete a circuit for alternator to charge properly.I think this is right alex.?????
Old Jan 4, 2006 | 01:04 PM
AlexF's Avatar
AlexF
Yes
The warning light exists as an easy way to power the field coils so the alternator will charge from very very low revs.
When you spin the alternator fast enough it will "self energise".
So when the alternator is functioning correctly it outputs a voltage from the field coils that matches the voltage trying to be fed to the alternator. This means that electricty won't flow and the light goes out.
Some cars alternator seem to fail but its just the bulb thats gone
Alex
Old Jan 4, 2006 | 01:06 PM
3drstretch's Avatar
3drstretch
As above.
Old Jan 4, 2006 | 01:08 PM
if ya belt is loose/slack can that cause the same?
Old Jan 4, 2006 | 02:01 PM
JimmyFlo's Avatar
JimmyFlo
ok so ill check my battery light as when driving normally below 3k it does seem to run rough as if its not gettin enoughpower for a good spark and if i have a lot of electrics on then it does just die and wont start again.
fordrallycar
Sep 30, 2015 07:57 PM
