What brakes pads to get ?
i have a sapphire 4x4 cossie and standard discs. I have been told to get ECB green stuff. Than when i called to get them i was told i need red stuff. As they have changed compound from Kevlar to ceramic. So now there bit when there are cold ?
so what one do i get. Or get some thing completely different
Originally Posted by gurnE
Mintex 1144 (1155 if you're a animal) or Ferodo DS2500
Personally I ran Mintex 1155 front & 1144 rear and found them excellent
I use Mintex 1144 all round including track days, no complaints (apart from black wheels from the dust
After all the bad things i have heard about EBC, i wouldnt bother, as they tend to warp discs somebody said. i personally run Ferodo DS2500's on front and rear, with Tar-ox Drilled and grooves discs. They work VERY well.
thanks m8. But i could put up with the dust.
Steer well clear of all colours of '...stuff' would be my advice.
Any of those mentioned above will be fine, or if your only planning 1 track day then even standard Motorcraft stuff should be okay.
