Rover alarms, anyone know anything about them? *UPDATE*
To stop the alarm going off u really need the key for the door lock, after re-connecting the battery, u need to shut the drivers door, lock it then un-lock it, this will stop the alarm from sounding every time u switch the ignition on. If you also find the fob u need the key to re-syncronize it to the system.
Originally Posted by Shings
its Lreg
Its not seized I just dont think the lock works with the 2 keys I have
I have never had the rover alarm fob.
Do you think I'll be able to do it from inside the door if I take the door card off?
Jake
Jake
arnt rover alrams systems in the ecus
im sure they cut the injector rail
just had the same problem with my mates even though he has a toad on it
luckily he had the fob which di activated it
always thought you need the fob tbh to de activate the alarm
Originally Posted by Rs Gus
Originally Posted by markk
external siemans units on them
and they were actully a lucas imob with spunkmans remote fobs
