Alright everyone, was just wondering if anyone could tell me the most easiest way to remove a sunroof from a series II ... and put it back in again. Cheers
Hi M8 right its a 5 minite job step1,push sun screen back ,step2,wind roof back so you can visibly see i think its 3 screws down each side looking from above,the roof should be 3 quaters of the way back,step 3 remove all screws think its 10 in total step 4remove winding handle,step5 sit inside car, with both hands drag the roof shut, step 6 from inside push the sunroof up and forward at the same time then should come straight out refit in reverse easy
