ABS light
LOL, i was only joking u cant take the bulb out
Buzzing? I dont see what there is to buzz to be fair, its mechanical ABS, im sure all the light does is connect to the belt break sensors, so the light should only ever come on if either the belt breaks or ive also heard that the switches get flicked out?
I've never had this ABS (and never will i might add) so i cant pin point anything
Im sure someone else that knows about it will see this post soon enough........hoping
mine did this mate, pain in the fuckin ass when it start flickering and ticking.....
replace the belts is the correct way of doing it, alternatively cut the fuckers in half or otherwise bypass the abs feed
just had mine done its the abs belts either they are loose or fooked driveshafts out job and a real pain the buzzing sound is a clicking sound that the relay is making there is a way to stop the clicking sound by bridging the wires together that comes from one of the abs pumps. Will put up a pic tomorrow of which wire it is if you are still stuck
