Where did you learn to Spray??
I dont really think its something that can be taught, you just pic it up as you go along, ive been painting for nearly 10 years know and iam still finding out better ways to do it.
Biggest tip i would offer though, is you can never rush paint work and you need the patince of a saint
I spent my childhhod watching my dad spray cars and just cpied what he did and picked up tips from friends in bodyshops over the years. Remember spray painting relieson good prep work if your preping is crap then you'll never get a good finish with the paint.
Also take your time never rush the job, i'm no expert so i'll probably get shot down here but also a tip i've found to be good is aways make sure your paint is warm. I usually stick my spray cans in a bucket of hot water.
I've recently bought a compressor and spraygun so i'm yet to try it out but i intend on practicing on some sheet of card to get the spray pattern right.
yeah as said before, you can read all the books in the world but experiance is what counts
im having to change over to water based paint as ive only used 2 pac
i think 2 pac is alot easier
Originally Posted by Itsmeagain
Originally Posted by RST_lee
How does it differ to 2pak?
Its spelt PACK
Spraying is not somthing you can buy a book on then know how to do. Just takes time and expirience. And it's right about the patience....
Buy yourself a gun, and a panel, and some paint, and just keep at it till your happy with it. Practise makes perfect.
It's all about your preparation, the more time you spend preparing your panel/car/whatever, the better your finish will be.
And don't give up when you make a balls of it. Cos, you will make a balls of it
No patchy silvers and flicks in well easy.
I used water for a year and then had to work with solvent base coat for 6 months and couldn't get used to it again.
How does this water based paint system work????
IMO it is 10 times better/easier to use and isn't as toxic as solvent based basecoat
Its spelt PACK
Go a googe search.
"2 pac paint" brings up about 2.5mil results, almost all about a dead rapper.
"2 pack paint" brings up 5mil results, about paint.
Its spelt PACK
Go a googe search.
you should get out more
Originally Posted by mercury grey minter
IF YOU WANT A PROFFESIONAL FINISH,GET A PROFFESIONAL.END OF STORY.
Oh I see
... I am self tought, no college training, no dad to teach me, all bookwork, reading and jumping in to try it.... ... Therefore I am not a timeserved painter, therefore not a professional IMO
Originally Posted by Freddy_mercury_magic
Ive seen Damo's work and to say im impressed is an understatment
Credit to him
Credit to him
Originally Posted by Tuffty
Else you end up with runs, hey ross
if you are going to learn the thecniques of spraying. you need to be wery patience. you need to get a common sense of what is happening with the paint when you aplly it, and you need to be clean with every thing you do. have seen a lot of good work be destroyed because the painter has been dirty, if you understand? my english writing sucks heheh
hope that was in any help too you. and that you understand what im trying too say,without any mistakes.as i said my english writing sucks
Credit to him
Credit to him
And yes all things can be improved on
Its spelt PACK
Go a googe search.
Its spelt PACK
Go a googe search.
Its spelt PACK
Go a googe search.
PMSL! Touche
because the paint was flaking off after only 1/2 a year!
