Crank Position Sensor
I am wanting to drill my block to allow a crank position sensor to run EFi. Has anyone got any specific measurements I can follow as I know this needs to be spot on position wise.
Dave
Dave
I dont have any measurements, but i do have 2 other options, make a template up from an EFI block and use that to drill, or buy a 36-1 trigger wheel and mount it on the pulley end of the crankshaft, you will also then be able to adjust the timing (if need be) aswell as not having to change your flywheel!
Thanks for the replies. I already have the EFi flywheel on as I replaced it a while back so I might aswell keep it original. I think it might make life a bit easier in the long run.
Dave
Dave
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
