lamba sensor add on kits, any good?
i remember reading in a mag a while ago about akit you put on and it gives you a dash display or something so you can see whats the fueling in doing.
anyone got one or anyone in the know about them can you give me some advise about them , or just general feedback on them
Lambda sensors and displays are only any good if they are wideband. Otherwise you might as well fit one of those xmas trees (lots of pretty twinkling lights) that truck drivers stick to their dash as that will be more use than the narrow band sensors.
the kits from what i can remember were quite expensive Ł300 or more so guessing that kit has got to be a real good one.
been flicking through my old fast fords but not found it yet.
got a few permormance fords i got to look through when i find them, lol
does anyone remember the bit in the mag im on about?
As daz sed,
if the kits Ł300, then its most prob a wide band, but you will need to check.
If so, yes well worth it, but only if you know the fuelin figure you need to be lookin for.
I wouldnt run my cars with out one,
Originally Posted by fiesta cossie
As daz sed,
what sort you got mate as in make, model, will give me a starting point as ive tried looking on the net but its not coming up with much
i run a Tech Edge wb02,
http://wbo2.com/order.htm
i paid Ł250 for the set up inc p+p, but then it cost Ł50 customs at the post office.
but know they have a UK agent, a bloke called Bill, and he's cheaper and a real Good bloke, as he done a warrentie fault on mine.
cool ill have a look.
found a few on ebay, this one looks ok, i know its cheap but is it the sort of thing im after? not gunn ahve a real big spec engine, same as what im running now just rebuilt, so would something like this do me?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MakeTrack=true
buy this
http://cgi.ebay.co.uk/Innovate-XD-1-...QQcmdZViewItem
the electronics and sensor are well proven
ooooh i like nice numbers thought, lol
not to sure about this number though,
buy it now price: Ł279.99
very nice i have to say, but was thinking something on the cheaper side of things, not because im tight, of skint, but because of the fact my engine isnt gunna be a real beefed up lump or used for track etc, just after something that will do the job without pulling my pants down
basically mate the narrow band ones like the one you posted is crap, it doesn't read a wide enough band (as the name suggests) and is basically just a gimmick.
to actually have it a useful readout you HAVE to have wideband, and <Ł300 is one of the cheaper ones!
whats this all about?
is it the same as what you posted up GARETH T
, but without the gauge, or just for use with a laptop or something?
http://cgi.ebay.co.uk/Innovate-LC-1-...QQcmdZViewItem
you would need a laptop to use it (or wire it into a narrow band gauge) and it would be accurate as its the same electronics as the one i showed earlyer!
im sure performance ford will show all
whats the one stu was banging on about recently called? i might get myself something like that
also what happenes if you replace your std sensor witha wideband one, will the ECU based closed loop still work?
gareth, i'm seriously tempted to buy that one in the link you just posted. does that do all the cool stuff the one stu posted before?
Originally Posted by PF Dave
Check out the latest Performance Ford guys, we've tested one of the better ones out there against the 'industry standard' mega-expensive kit, and it did pretty bloody well!
Dave could you do a group test, all on the same day?
all usin same sensor, and calibrated.
as i think that will be better.
http://www.zeitronix.com/questions/Zt-2questions.htm
these are very good things for about the price of a tech edge one
i can get these for 220 delivered u can log ur afr on this to
http://www.turbobits.co.uk/acatalog/...io_gauges.html
hth cheers jay
hth cheers jay
Stu uses the Dynojet kit.
JayRS, read this link.
https://passionford.com/forum/viewto...asc&highlight=
thats the link i forgot to put in my post, lol
not really after dater logging, but seeing as there is a kit about, is it possable to link it to a screen inside the car?
i asked a question a long time ago now about having stuff like bosst etc displayed on a screen in the car but was told the ecu was no good fo it, it was later car (someone said at the time about jap cars can do it) that could only have a system like this.
i know its getting away from the origanl question but i have never really looked into add on bits along these lines so appoligies for the "dumb" approach to all this
jayRS
anything possible mate,, why not study electronics and have a go at moking one yourself?
wiring it all in etc would be easy but the electronics just aint my thing
i'm a bit of a twat when it comes to this
gareth, what does stu's dynoject on do that the ebay one doesn't?
if its just the activation thingie then i'd gt the ebay one. datalogging would certainly be cool tho
so not really worth the extra 100something quid just for the warning feature and the activation feature really ?
