WHAT CAR'S DO U HAVE?
At the mo the missus and i own.... :
Escort Cos ( Imp blue )
Sapphire Cos 4x4 ( Silver and FORSALE
Escort RS 2000 4x4 Mk6/7 ( Silver )
L reg Nova GSi (Silver )
Citroen Zsara 2.0 HDI ( Met Red )
Originally Posted by rizla
Originally Posted by RST TOM
JUST OUT OF INTREST WHAT CARS DO U ALL HAVE?
and a Rreg transit
and a Rreg transit
Originally Posted by staffi
3 door, stage 3, T34, 500cooler, GRP.A Gasket, greens, etc. mapped by Karl Norris, dynod, @ 343bhp, 337 ft torque.........want more now though?
well i dont drive as i am 16 but these are the cars my dad(rsjp) has had (he has had more when i was younger but i cba to list them).
(oh all the cars are sold on now
his standard rs500
his texaco cosworth replica
And the best
Brooklyn Touring Car Replica
ENGINE
Brooklyn motosport works 200 block bored out 0.25, long studs, fully lightened and balanced out sump, fully machined pistons ported polished and gas flow headed btcc head with wcr head gasket, 3 bar map sensor group a coil ahmed bayjoo air injectors rs500 eight rail and eight green 803 cc injectors ggr fuel pressure regulator four race fuel pumps fuel swirl pot braided lines t4 turbo rs500 intercooler magnex exhaust system with lambda sensor k&n filter in air box oil coler level 8 ecu with ahmed bayjoo map power 500bhp and 440 lbf.ft at 34 psi
TRANSMISSION
rebuilt t5 5 speed gearbox shot peened gears, straight cut gears, rear wheel drive lsd alcon 6 paddle clutch quaife diff
SUSPENSION
works shell seam welded works roll cage bilstein coil over suspension with 500 over 200 inserts 600lb front and 360 over 130 insters 200lb rear springs front ajustables track control arms race brushes
BRAKES
ap racing 330mm floating discs with 6 pot calipers, 4 pot rear calipers with 315mm discs, brake bias system and a hydraulic handbrake
WHEELS & TYRES
7 x 17 tsm imolas in black with 240 x 610 bf goodridge slicks ( 8 x 17 rear)
BODY
competion three door cosworth shell with offical brroklyn motorsport btcc car race graphics
INTERIOR
sparco race seats and harnesses secs engine monitor display procomp volts water temp and boost pressurs gauges momo steering wheel starter button kill switch
THANKS
Andy Fisher of Brooklyn Motorsport, my son
[/img]
his standard rs500
And the best
ENGINE
TRANSMISSION
SUSPENSION
BRAKES
WHEELS & TYRES
BODY
INTERIOR
THANKS
[/img]
