lowering & Abs
it will only interfere with ya load preportion valves on the back of the car!
this adjusts braking power to the rear brakes dependant on the weight in the car! if the car is high at the rear eg no weight it will lower the efficiency or if its low eg people in the back or been lowered loads it will give full braking power to the rear!
then it gets a bit hair raisin brakin round corners!
60mm !!!!
Too far mate. Specially if you have a mint car. Don't want to spoil it by going too low: looks or bodywork. May also need to trim the rear arches to stop scrubbage at that height/lowness. Stick to 25/30mm tops as a good compromise for looks and handling.
