Problem freezing plug
Hi All,
Question there is a sort of freezing plug in the front of my FRST block and it sprung out twice, so my cooling fluid is drowning out of my block whitin 10 sec. And it happened twice at the exact same moment. I was driving in 3th gear for over a couple of minutes(3500 rpm) then switching to the 4th gear and putting the pedal on the floor and then the plug sprung out.
Does anybody knows this problem?
Chreers
Chreers
In the Netherlands is Antifreeze and coolant not the same. Antifreeze is the one you have to mix yourself whit water. But I use only pure cooling fluid. Or maybe I have translated the word wrong
The coolant i use protecs till -26 degrees. And its cold here in the netherlands but only 0 degrees till -4 max. So it wasn't frozen.
And when the first one went out i''ve fitted a brand new one. Could be there something else that cousses to much pressure on the cooling system?
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
