picture request - s2
Has anyone got or can anyone get some close up pictures of the metering head on a s2 with the pipes going to it and also how/where the fuel pressure regulator is mounted and also the accumulator? Also where the feed pipes are routed when they come up form the base of the bulkhead. Also the location/routing of the brake lines especially the exact location of the t-piece where it mounts to the wings?
Thanks in advance
Stephen
Thanks in advance
Stephen
fuel pressure regulator is the grey\black box on the right hand side of the metering head if your look at it from above.
The fuel accumlator bolts to a bracket on the same side as the metering head, just beding it, the bracket screws in with 3 screws, and then the strap locates the accumulator to it.
There is also a fuel pressure valve which sits on a little craddle mounted on the left side of the metering head.
Hope this all helps, will get some pictures up tonight to make it all clearer.
Regards the T -Peice's and brake pipes, have got any pictures of them so cant help sorry
Thanks Ryan. I could do with the pics from a series 1 regarding the brake pipes if anyone has some cos im removing abs at same time and want to know how the pipes route around the bay.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
