revs all over the place
Old Dec 28, 2005 | 05:24 PM
RST Ski's Avatar
RST Ski
Default revs all over the place
started me car up jus now, rev counter is up n down all over the place???? any ideas?
Old Dec 28, 2005 | 08:27 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Auxilary Air Valve?
Old Dec 28, 2005 | 08:49 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
As tony said, if not then check for any leaks in boost hoses or vacume hoses. doubt it tho. especially check vacume hose to ECU. also dump valve could be a prob.
Old Dec 28, 2005 | 09:00 PM
Combi_Chris's Avatar
Combi_Chris
water temp sensor ??
mines the same and its the water temp sensor its ok when its warm tho.............
Old Dec 28, 2005 | 09:55 PM
Damienholmes's Avatar
Damienholmes
Sounds abit strange, but i had the same problem - and i found out my metering unit was FOOKed
Old Dec 29, 2005 | 04:29 PM
RST Ski's Avatar
RST Ski
idle itself doesnt go up n down, jus the needle rev counter itself
Old Dec 29, 2005 | 04:43 PM
antony215's Avatar
antony215
Escort Rs Turbo
Conections on the rev counter itself i had a set in my old xr3i that done the same everytime i whent over a bump the rev counter whent up and down put a new set of clocks in and it was fine
Old Dec 29, 2005 | 04:44 PM
Damienholmes
Always something so simple
Old Dec 29, 2005 | 05:50 PM
RST Ski's Avatar
RST Ski
gcfcos
59
Oct 6, 2015 05:04 PM
Kam B
Sep 30, 2015 01:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
