COSSIE BRAKES ON S2
Originally Posted by Freddy_mercury_magic
IMO, the 4x4 fronts brakes are better
No machining and they fit straight on iirc
CHEERS GUYS,AM CURRENTLY USING COSSIE DISC ALL ROUND WITH ADAPTER BRACKETS UP FRONT TO KEEP MY ORIGINAL CALAPERS,BUT AM FISHING FOR IDEAS.DIDNT WANT TO SPEND BIG MONEY ON BREMBO,WILLWOOD,E.C.T.
as jambo says 4x4s + 2wd discs are okay, but you actually get more surface area with std calipers and 2wd discs.
st170 is a brilliant setup but need at least 16s......
if you're on a budget then just get a pair of rainbird brackets and stick some 280mm cossie discs on
Ive fitted a full cossie 2wd set up to mine, and theyre not all that IMO. The master cylinder isnt up to the job, needs to be larger otherwise theres a noticeable difference in pedal travel (although without the rear discs it will be fine), although i havent really properly run them in or had a good drive in it yet as i need to MOT it.
Some of the comments above are feasable, lots of people have the ST170's, and the standard calipers with cossie pads make sense surface area is what its all about!
SORRY FOR ANY CONFUSION,I HAVE COSSIE DISCS ON FRONT &REAR.THE REAR CALLIPERS ARE 2WD THE FRONT CALLIPERS ARE STANDARD RS TURBO CALLIPERS WITH ADAPTER BRACKET TO RAISE THE CALIPER TO ALLOW COSSIE DISCS TO FIT.THE BRACKET BOLTS IN ORIGINAL CALIPER MOUNTING HOLES.GOT THE KIT FROM (COSSIE CLINT) AT TURBOSPORT .CO.UK.THEY HAVE PICTURES ON THERE FOR STEP BY STEP GUIDE.HOPE THIS HELP.
