AP Calipers
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Got a pair of 'lug mount' ap calipers with CP3307 marked on them. Any body got any info on them ?
Thanks in advance.
Thanks in advance.
cp 3307 is the "family " name for these 4 pots , they tend to be used as Group A Fitment rear calipers on 295-315mm x 28mm vented discs . You can use them on the front as well of course as long as you maintain them in the same orientation (leading or trailing ) .
aka Turbosailorboy
Cheers Tony,
i've got CP5200 4 Pots with 330mm discs on the front already and i wanted to fit these to the rear but had no idea about disc size
Thanks alot for that info.
