Cossie brakes
fitted cossie brakes all round to my MK5, with the same master cylinder ad the old brakes, the rear brakes are a bit keen, as in they lock up before the fronts..... Lethal
what should the percentage be between the 2 brakes, 100% being the fronts, where should the rears be?? around 70%???? Any info will be good, regards. pete
generally ya need about 70 to 80% pressure to the front if you whack em on hard. otherwise 60 to 70% normally. i'm guessing you dont want the latter. otherwise you wouldnt have upgraded.
if you want 70/30, f/r... 30 is less than half the pressure of 70. (obviously)
so if as you say, 100% on the front, you'd be looking at about 35% on the rear.
right, i upgraded because the 1.6 std brakes and drums werent any good for a 170bhp rst motor and ive just ordered a cam kit and have got my front mount cooler to go on to so opting for 200bhp but want to get brakes right beforehand, ive ordered gaz coilovers too, im trying to get a good all round car...
well the car wieghs nothing, dashboard, 2 cobra seats and a full SD roll cage so i cant afford for the back brakes to be locking up mid corner
Pic here..... Not everyone,s cup of tea i know.....
well the shell cost me just short of £200 and the cossie wings and skirts about £300 SD cage £200 seats £200, brakes £100 and rs running gear + all other bits inc cams, chips ect about £700 so it aint MEGA bucks
