cosworth prop question
Old Dec 26, 2005 | 06:09 PM
abdr500's Avatar
abdr500
Default cosworth prop question
hi. a 1 piece prop does that do away with the center bearing and how will it work as the bearing takes alot of vibration and load when taking up drive and what about when the car lifts of a littel
Old Dec 26, 2005 | 06:32 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: cosworth prop question
a one piece prop will replace a split prop but is susceptible to more vibration...it will be larger o/d than the original two piece and the longer it is the bigger the diameter will have to be for a given rpm usage so a long prop would probably be better in a split format. here's my single rear prop together with the front one..
Old Dec 26, 2005 | 08:31 PM
abdr500's Avatar
abdr500
very nice you have pm
Anutternutter
24
Aug 31, 2015 01:24 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
cossie330
Aug 22, 2015 12:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
