Roll cage bender
Old Dec 26, 2005 | 02:37 PM
lancia delta 6 times WRC's Avatar
Default Roll cage bender
Do you guys think there would be a market for one if i was to develop one for home use suitable for CDS tubing, stainless and possibly exhausts
I guesstimate price would be around £300-400, just reasearching ATM.
Old Dec 26, 2005 | 03:14 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
A mandrel is an articulated rod inserted inside the tubing being bent, it very basically supports the walls walls of the tube and stops them from collapsing or deforming. You can get a lot tigher radius bends with a mandrel bender.
If using a compression bender, which doesn't use a mandrel you'll get kinks, stretches and deformations in the walls of the tubes.
I would possibly be interested in one...depending on what type of be bending machine it is?
Old Dec 26, 2005 | 03:25 PM
Something along the lines of this,
[IMG]http://img.photobucket.com/albums/v19/stu8v/rollbar02.jpg[IMG]
Old Dec 26, 2005 | 03:27 PM
GVK's Avatar
GVK
html doesn't work on these boards
Old Dec 26, 2005 | 03:40 PM
Jamz's Avatar
Jamz
I looked into making that but I couldn't find anywhere in the UK to get the dies from.
Old Dec 26, 2005 | 03:47 PM
I was planning on machining them.
boeb
Jan 9, 2020 05:11 AM
SMILER258
Sep 28, 2015 09:04 AM
Mikersturbo
Sep 27, 2015 07:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
