Swedish "WRC" Escort Cosworth :) upd pics 060213 p
Looks realy nice m8... Question, I have a video with a black Rx 7, Benz E55 AMG, Escort WRC and an Audi S2.. Driving up and down thrue a tunnel.. Is this maybe that WRC escort, cause in the movie it was also a red one... Got Anti Legg.
very nice esc cos m8. red with white wheels
Originally Posted by rs cos
any engine stats?
Just hope the R&D 6speed box is up fore it :=)
Some spec :
Arrow rods
JE Pistons
Special T04S stage5 inconell with T-netics extern wg
Autronic SM2 managment
MSD 1000cc injectors
2x Walbro 255l pumps
etc etc...
Henrik
Originally Posted by Escort_Cos
very nice. i like it
just one question. what is the spec of your t4 to allow it to flow enough for 550-600 bhp?
The Turbo is a well keept secret
Henrik
any engine stats?
Some spec :
Arrow rods
JE Pistons
Special T04 stage5 inconell with T-netics extern wg
etc etc...
Henrik
since you also use 1000cc injectors you need 4 liters a minute of fuel which the internal shitty pumps cant deliver
So i am very curious how you set it up .. because i am faced with the same problem if i dont want my engine to blow up on me
any engine stats?
Some spec :
Arrow rods
JE Pistons
etc etc...
Henrik
The crap orginal pump goes to the scrapheap and 2pc of Walbro 255l/min goes in the tank ( they do fit but its tight
Henrik
Ok, ill try my best to explain on my shitty english..
and i use 2 seperate lines under the car with 2 filters. Then i have remodelled the fuelrail so it has fuel in on both ends and the regulator and return line on the mittle...
Henrik
Henrik
a picture of it would be to much to ask ??
I like this solution a lot better then putting a fuel cell with swirlpot in the boot
Henrik
Henrik
I thought you were using 8 greens???
Because in that case, you can just put fuelpump 1 on injectorrail 1, and number 2 on injectorrail 2???
Henrik
Henrik
i have a black one also .. which will meet you on the sprint race if you can find your balls
thats the blue escort ..
Balls will be there, no probs, but only if the distance is 400 mtr.
for details -->> http://www.fulltuningweekend.org
see you there ?
@turbinator: Lommel sounds good, never been there. Maybe we will come have a look if the car is ready (new diff and gearbox still to come).
I think we won't be at Landgraaf this year tho...
