rst van lowered?
I know someone in germany who makes lowered leaf-springs for the van. I'd prefer the OEM way of bolting the axle(under the spring), but they are very expensive (~2000Euro or £1350)
Maybe there are some guys in UK who make cheaper ones??
hi mate ive lowered my mk4 escort van & its very low it cost me about £35.00.iwil post some pics 2morrow all you is a set of lowering blocks 4 a mk1/2 ford cortina & a little bit of modding it took me & my son about 45 mins & it was so easy. heres the web site 4 the blocks www.speedshack.co.uk
u can put axle above useing standard bolts/parts but u will have 2 weld on some rear shock brackets to hold bottom of the shock on.
do it same way as pictured above but put the top plate (standard) on the bottom & loop the u bolts over axle threw the plate & put the nuts on the bottom.
but leaves u no shock mounting (as its on bottom plate).
on my old express van i just had a spring company straighten them 30mm. whit gave 90-100mm off lowering...don't have any pics..
just remember to adjust the alb-valve....
http://i2.photobucket.com/albums/y44...van/div_04.jpg
http://i2.photobucket.com/albums/y44...van/div_01.jpg
[/img]
