Spray painters
Old Dec 25, 2005 | 01:13 PM
Micky's Avatar
Micky
Default Spray painters
Hi lads,I'm being watching all these proper spray painters on tv,shows like American Chopper,Biker Build Off etc etc and notice that after they've sprayed and lacquered a tank/mudguard etc they rub it done with fine sandpaper.Seen them do this on American Hotrod too.Can any experts on ere tell us what grade sandpaper this is,why its done etc etc.What the proper procedure when spraying???Is the paint rubbed down between coats etc etc???Any help from those in the know would be welcomed.Thanks in advance,Micky
Old Dec 25, 2005 | 01:16 PM
Damo V's Avatar
Damo V
Often final coats are rubbed back to remove slight imperfections, they may use 1200-1500-2000 grade aswell as 3500 micropad things
Old Dec 25, 2005 | 01:28 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
When i do small bike parts, I've used grades up to 12000 and start from 1200 like Damo says..
With a polishing compound they come up a treat
Here are two parts i done a few weeks back of an old BSA a friend is restoring
( This hasnt been polished yet either! )
Old Dec 25, 2005 | 01:30 PM
svony's Avatar
svony
It's commonly know here as wet sanding (wet sandpaper and dish washing liquid). As stated above, the process allows for the removal of any imperfections and also a better shine. After the car is completely sanded rubbing compound is applied using a buffing machine, this gives you that smooth as glass finish. The final step is hand polishing for the shine.
Old Dec 25, 2005 | 01:35 PM
Micky's Avatar
Micky
Freddy_mercury_magic,that black looks bloody fantastic,like a mirror Cant even imagine how much better it will be when you polish it.Regards Micky
Old Dec 25, 2005 | 01:39 PM
Charlie Chalk
Unknown.
Thanks
Old Dec 25, 2005 | 03:00 PM
RS_Rawli's Avatar
RS_Rawli
flatting its called
as above
1200 up to about 3500 usually
bloody hard work, but it brings it up like glass
rsguy
44
Sep 29, 2015 03:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
coscor86
Sep 20, 2015 01:21 PM
