engines for sale
Cosworth engines
RS500 cosworth engine, in 4WD trim, fully rebuilt, with motorsport 200 long studded block, polished and ported head, WRC head gasket, BD14 cams, WRC 8 injector inlet manifold and fuel rail, New T4 motorsport turbo, high torque exhaust manifold, high pressure oil pump with oil spray system, polished con rods, lightened and balanced crank, new water pump, big wing alloy sump, motorsport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, AP paddle clutch , all new seals and bearings, 6800 pounds
mountune clubman GPA cosworth engine, 4WD ,fully rebuilt, with motorsport 200 long studded block, WRC head gasket, New motorsport turbo, high torque exhaust manifold, high pressure oil pump with oil spray system, lightened and balanced crank and rods, new water pump, big wing alloy sump, motorsport cam belt, New anti pump cam followers, Aero spec oil hoses, lightened and balanced fly wheel, AP paddle clutch, 4500 pounds
rog
Sep 4, 2015 12:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
