3 door sieras
if you chop the piler out of a XR4i, they rot there in time, use a 1.6l if you must!
Quote[ You need a 1.6l doner car for the glass and the bit's to fill the area from where the pillar is cut out and to change the shape of the window appature at the rear . It look's good when it's done right , but it's prone to cracking if you use too much filler to skim over the joints where the welds are . ]
chowfornow
14
Jan 5, 2019 09:01 PM
Vacuman
Sep 22, 2015 12:09 PM
