need advice
Old Dec 20, 2005 | 03:16 PM
jonnyfrst's Avatar
jonnyfrst
Default need advice
hi all again i have juts found out that ma car has used 6L off oil over 2weeks and there is alot off white smoke coming out the exhaust when im sitting with the car running any ideas what it could be
Old Dec 20, 2005 | 03:22 PM
Ezzy Danny's Avatar
Ezzy Danny
i think, but stand corrected if wrong that turbo = white smoke engine = blue smoke. but which ever it normally means its goona be expensive
Old Dec 20, 2005 | 03:24 PM
jonnyfrst's Avatar
jonnyfrst
cheers mate and also all the oil i have been putting into it and now there is no oil left at all
Old Dec 20, 2005 | 03:41 PM
Ezzy Danny's Avatar
Ezzy Danny
sounds like a bomb mate if there no oil in its ready to blow, hope u got deep pockets it happend with mine and i had to replace turbo and engine
But as always when its done its great!!! may aswel get a 2.0l zetec bottom end from the scrappers cheap as chips not that hard to fix. and they are much stronger engines. if ya going for power change the pistons and you'l have a beast lol
hope you really love the car theres lots of work ahead!
Old Dec 20, 2005 | 03:42 PM
addiction's Avatar
addiction
does it smoke when coming on or off boost?
Old Dec 20, 2005 | 03:46 PM
jonnyfrst's Avatar
jonnyfrst
i dont know mate as im driving at nite alot but it smokes alot when im sitting chatting 2 friends
Old Dec 20, 2005 | 03:49 PM
jonnyfrst's Avatar
jonnyfrst
ah well here goes alot off hassle lol and i was also told it had a recon engine and rebuild 2months ago
Old Dec 20, 2005 | 05:22 PM
SafeChav's Avatar
SafeChav
first things first check the basics, like is the oil/collant creamy?
And do a compression test. That will start to narrow it down a lot!
Better get earning some cash though not guna be a cheap one
Old Dec 20, 2005 | 05:41 PM
jonnyfrst's Avatar
jonnyfrst
i know thats the RS life for u
Old Dec 20, 2005 | 07:22 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
stop nattering down kirkaldy and get it sorted.
Old Dec 20, 2005 | 07:28 PM
jonnyfrst's Avatar
jonnyfrst
its off the road now as i checked the oil again 2day and its all gone so its off the road till its fixed
Old Dec 20, 2005 | 07:29 PM
akito-man's Avatar
akito-man
Old Dec 20, 2005 | 08:03 PM
jonnyfrst's Avatar
jonnyfrst
i have found that there is a crack in the turbo between the oil and waterways could that be the problem for me losen so much oil
Old Dec 20, 2005 | 08:05 PM
SafeChav's Avatar
SafeChav
Definately
New Turbo pleaseeeeeeeeeeee
Old Dec 20, 2005 | 08:06 PM
jonnyfrst's Avatar
jonnyfrst
so its not the head gasket them for sure ites the turbo
Old Dec 20, 2005 | 08:08 PM
SafeChav's Avatar
SafeChav
Could be both
Do a compression test its the only way short of taking the head off.
Thing is just cos the turbo is cracked and the oil/collant is mixing wouldnt necessarily make it smoke.
I expect the oil has been ruined and has been like it for some time and possibly the rings have gone, or it may have caused overheating and made the headgasket go.
Compression test.......get on it
Old Dec 20, 2005 | 08:11 PM
jonnyfrst's Avatar
jonnyfrst
its had a compression test and thats all good
and also has had the gasket changed not long ago cos it was gone
Old Dec 20, 2005 | 08:13 PM
SafeChav's Avatar
SafeChav
Oh ok
well definately the turbo needs changing, and give it an oil change new filter etc, and change the coolant.
Have to go from there really, if compression test is all good cant be a lot wrong with the engine....
Old Dec 20, 2005 | 08:15 PM
jonnyfrst's Avatar
jonnyfrst
cool i will get that done asap once i can find some parts 2 sort it all out
Old Dec 20, 2005 | 08:19 PM
SafeChav's Avatar
SafeChav
buy a new turbo second hand ones are touch and go
Old Dec 20, 2005 | 08:23 PM
jonnyfrst's Avatar
jonnyfrst
cheers all and here goes for more fun
Old Dec 21, 2005 | 09:54 AM
mat-nos's Avatar
mat-nos
just as a thought what grade oil are you using??
and deffo get a new turbo lol
Old Dec 21, 2005 | 10:38 AM
jonnyfrst's Avatar
jonnyfrst
5w/40w as it states
also i have had the car out for a wee run 2day with oil in it and when i come off the throtle there is alot off white smoke pouring out the back and even when im on the throtle on boost so i take it the turbo has gone bit time then
Old Dec 21, 2005 | 12:15 PM
jonnyfrst's Avatar
jonnyfrst
this is not lookling good at all jus ttaken off the boost pipes and the intercooler is full off oil and i think there is about 4L off oil on ma driveway now can anyone shed some light on this for me
SafeChav's Avatar
SafeChav
yeah sounds like it
ah well just have to get a better one
Old Dec 21, 2005 | 12:16 PM
SafeChav's Avatar
SafeChav
Thats the oil seals gone on the turbo mate, that turbo is Ragu!!!!
New one will sort that out
Old Dec 21, 2005 | 12:18 PM
jonnyfrst's Avatar
jonnyfrst
what can i do about the intercooler and the metering head as there oil is just coming out off them
Old Dec 21, 2005 | 12:22 PM
SafeChav's Avatar
SafeChav
ummmmm, tar and glue remover to clean the hoses, and u can split the metering head in half, and use like brake cleaner or similar, intercooler is always a bitch but u could just spray a bit of brake cleaner down that too, u always get a trace of oil in them so dont worry about the intercooler too much
Old Dec 21, 2005 | 12:23 PM
jonnyfrst's Avatar
jonnyfrst
i have only had the car 2 weeks and already im getting sick off it and i really dont want 2 do more damage 2 the car
Old Dec 21, 2005 | 12:28 PM
SafeChav's Avatar
SafeChav
the same sad old story with a second hand performance car
U usually do spend a while picking up the peices from the previous owner but u can then rest assured youve done the job properly. U cant damage anything, if u dont want to split the metering head just spray brake cleaner in the hose inlet and get a rag in there, thats the lowest point so there shouldnt be anymore oil in it, and tar and glue remover is the dogs for cleaning samco.
Hang in there mate you know its worth it Vrrrrrrmmmmmmmm Tiiiiiiisssssshhhhhhh
Old Dec 21, 2005 | 12:48 PM
jonnyfrst's Avatar
jonnyfrst
hopefully it will be worth it mate cos im about 2 lose ma rag with the car and others said it was not a good idea for the guy 2 swap it with me as all i has was an xr2i in mint cond but he did so i think the car was on its way and he thought why not get rid let someone else have the hassle
Old Dec 21, 2005 | 12:58 PM
Kop2381's Avatar
Kop2381
Its not that bad mate couid of bin a lot worse if it is the turbo
Old Dec 21, 2005 | 01:00 PM
jonnyfrst's Avatar
jonnyfrst
its going 2 be the turbo or the head or both and that will cost a nice penny 2 sort out not more money on the run up 2 xmas after everything else
Old Dec 21, 2005 | 01:06 PM
Kop2381's Avatar
Kop2381
No what you mean mate it starts to get you down but once its sorted and running sweet again youl forget all about it
Old Dec 21, 2005 | 01:11 PM
jonnyfrst's Avatar
jonnyfrst
hopefully it will be or i will end up putting a match 2 it thats how bad its getting
Old Dec 22, 2005 | 01:27 AM
jonnyfrst's Avatar
jonnyfrst
cheers everyone i will tray a new turbo on it mite as well upgrade the now while this one has gone
Old Dec 30, 2005 | 06:14 PM
FordRallyeSport's Avatar
FordRallyeSport
She running well better now tho mate!!!!!
Old Dec 30, 2005 | 06:30 PM
jonnyfrst's Avatar
jonnyfrst
dam right she is mate and all down 2 urself
also running better boost and much much better than when it was before
Old Dec 30, 2005 | 06:39 PM
FordRallyeSport
She be even better with some sensible mods as its a good engine there...... But then you now no that already!! lol
Always happy to help out a fellow Ford Man........
Old Dec 30, 2005 | 06:40 PM
jonnyfrst's Avatar
jonnyfrst
thats all coming after the new year mate
