1/4 mile - just how fast is fast???
Old Dec 19, 2005 | 06:58 PM
Moose 130's Avatar
Moose 130
Default 1/4 mile - just how fast is fast???
can you state the best times you've run and the state of tune of your Cossies please.
Interested to know what stage 1 through 3 run in particular.
Old Dec 19, 2005 | 07:08 PM
Basky's Avatar
Basky
12.60 saff cos ,low comp,d and running greys t 35
Old Dec 19, 2005 | 08:41 PM
rog's Avatar
rog
12.7sec 1/4mile
Stage 3 chip, greens, piper x filter, mongoose, etc, std 4x4 cooler and T3, and lots of revs on launch.
Wouldn't do that now as the engine is rather fooked i think.
Old Dec 19, 2005 | 08:48 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
10.66 @ 138mph using 1.8bar boost with GT35 turbo on 2.3 alloy block engine so probably 570hp
Old Dec 19, 2005 | 09:03 PM
boXXer's Avatar
boXXer
GASH!
13.4 stg 1 gunship.
Old Dec 19, 2005 | 09:04 PM
mmanse's Avatar
mmanse
12.9 on greens and 500 intercooler and t34. rwd
Old Dec 19, 2005 | 09:38 PM
Danny B's Avatar
Danny B
12.01@at 117mph greys, own inlet,own intercooler, 22psi boost T34 .63hsg, non standard engine.
2wd saph.
now for the annoying bit, 12.32@108mph on a worn out oil burner standard cossie engine with greens, 3 bar, 24psi on standard 82000mile T3. but the 1.61sec 60ft helped.
Old Dec 19, 2005 | 09:45 PM
Martin-Hadland
2wd saph.
was that on one of your 'special' axles?
Old Dec 19, 2005 | 09:55 PM
Danny B's Avatar
Danny B
2wd saph.
what the so called......Transit axle!!
haha, yes thats with the 8.8 rear end and this was on a 3.31 ring and pinion!!! will be a little different when it next see the track.
Old Dec 19, 2005 | 10:09 PM
FasterFords's Avatar
FasterFords
13.5 Standard Mk2 Mexico, well, a standard-ish Cossie Turbo motor
Old Dec 19, 2005 | 10:10 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
what strips you guys using?
cant get my saff under 13.7 at york dragway (REALLY REALLY bad strip)
lightened/balanced/shot peened bottom end with 8.8:1 CR
light port head/either standard or BD10 cams (cant remember what i had lying about!)
greys
t35 .48 only 17psi! with antislag though
with the T4 my first ever run when perf ford featured the car @ york dragway i got an 18sec pass
wheelspin in 4th gear
just goes to show how bad the strip is i guess.
cant wait to try my new engine/turbo setup at york and then ultimatley at the pod
regards Sean.
p.s fastest 2wd cossie i saw at york was a flint 2wd saff manadging to get 12.7!!!!!!!!!!!!
greens, T34, 500 cooler.
would have won the ford shootout if it wasnt for a bit of dodgy timing opperators..............
Old Dec 19, 2005 | 10:15 PM
Kevin Sharp's Avatar
Kevin Sharp
10.3 sec @142mph stage 3 lardy luxpack escos
Old Dec 19, 2005 | 10:31 PM
simonc's Avatar
simonc
3dr cosworth, greens T34 .48 , RS500 i/c, L8 pectel bb, verniers, 20 psi boost, standard comp, Paul hills map.
Only been to the pod once on this spec engine.
13.4 @ 107mph, i'm sure i could better it, can't understand why my terminals are low for the spec, would like to see around 110-112mph,any ideas ?
Simon.
Old Dec 19, 2005 | 11:19 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Simon.
You forgot to mention that was also with all the seats removed
As sig, with all my seats as well.
Steve.
Old Dec 19, 2005 | 11:20 PM
Jim Galbally's Avatar
Jim Galbally
see sig, however mine's had a van engine fitted
Old Dec 19, 2005 | 11:50 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
mines in my sig, done at pod. guess you'd call it a 'stage 2'
Old Dec 20, 2005 | 12:04 AM
aduz's Avatar
aduz
does anyone reckon we'll see a 9 sec uk cozzy?
Old Dec 20, 2005 | 12:05 AM
Kevin Sharp
yes!
Old Dec 20, 2005 | 12:41 AM
aduz's Avatar
aduz
yes!
building something are we?
Old Dec 20, 2005 | 12:43 AM
Unless you shut your eyes every time martin runs i would say its a foregone conclusion given that he was only .7 seconds away before, and the gearbox must be worth half a second!
Old Dec 20, 2005 | 12:47 AM
Is that on road legal tyres?
Any details of the engine you feel like giving away (like what turbo etc), or is it all "top secret" as per usual in the world of fords
Old Dec 20, 2005 | 12:50 AM
Kevin Sharp
how do you calculate that chip? changing froma dog box to a sequetial aint going to give half a second
and to add mine is 10.88@133ish off gas with a 2.0 yb
Old Dec 20, 2005 | 12:52 AM
Kevin Sharp
no its T4 8inj old scholl with a proper gearbox , new car lighter ready soon
Old Dec 20, 2005 | 12:53 AM
Kevin Sharp
and yes road legal tyres!
Old Dec 20, 2005 | 12:54 AM
aduz's Avatar
aduz
Old Dec 20, 2005 | 01:02 AM
Oh i didnt realise he was on a dog box before
I will take my gracefully then.
for some reason i thought he was on a fixit kit for some reason, but that does just sound daft now i type it
Old Dec 20, 2005 | 01:04 AM
10.88 off gas on road legals and still a 2.0 YB is one of the most impressive things ive ever heard!
Especially given what you said about the spec of the engine.
Just goes to show how perfectly setup it is and how good at launching it you must be!
That really is fucking amazing
Old Dec 20, 2005 | 01:06 AM
sunny's Avatar
sunny
aka Kev McSnapper!
Old Dec 20, 2005 | 07:45 AM
Danny B's Avatar
Danny B
Impressive thing with Kev is that He still hasnot ran a full drag radial, he's on a fast road tyre, When they were out kev give me a call, I can do very good deals on Avon Track day tyres now like the ZZR
or of course a propper drag radial
I think there will be at least 3 9second 4x4 cossie's this year, maybe even the odd 2wd.
Old Dec 20, 2005 | 09:54 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Craig,
14.462 in my gay 4x4 which is stage 1.
I wasn't trying too hard though, I wanted to get the car back home in one piece, it should be possible to run it quicker with less mechanical sympathy.
(and it had a bootfull of ice / clothes, etc...).
Old Dec 20, 2005 | 02:00 PM
Kevin Sharp
i,m anything but the perfect launcher chip..1.7 60ft is my best....must be those dodgy tyres danny sold me
send me some of those tyres free for evaluation puposes danny
Old Dec 20, 2005 | 02:06 PM
1.7 is good but yeah nothing specatular, i am frankly at a total loss as to how you are managing those times then, unless its at crail which ive heard is downhill
Seriously though, Have you ever run at the pod?
Old Dec 20, 2005 | 02:27 PM
Kevin Sharp
crail aint downhill
never run at the pod....had redlines datron on it once at brunters did 10.8 @135 on my second attempt with alittle gas prob running about a 50 shot that day but it started raining before i could try anymore and i had a bad topend misfire anyways to run the 10.3,s and 10.4s i recon i had around 650bhp which is about right with the 140mph+ terminals
heres a timing slip for anyone interested
Old Dec 20, 2005 | 02:39 PM
Wahoo, a successful bit of fishing with the crail comment, i caught a live one
Thats a fucking impressive slip mate, just goes to show what a REAL 600bhp car actually does, rather than the BS 600bhp that most people claim to have!
Old Dec 20, 2005 | 02:43 PM
Smit's Avatar
Smit
The 60ft Launch King
Still got the vid of you wasting that gold supra Kev
Old Dec 20, 2005 | 02:46 PM
Kevin Sharp
ha i was just watching that the other day smit i have another vid of a couple of 10s runs against bikes if anyone can host them? i dont know how
Old Dec 20, 2005 | 02:59 PM
Smit's Avatar
Smit
i just remember who-ever was filming it....
'900 horse power my arse'
Old Dec 20, 2005 | 03:00 PM
Kevin Sharp
that was a guy i know..simon...he,s lucky he didnt get a kicking off them for that!
Old Dec 20, 2005 | 03:41 PM
Smit's Avatar
Smit
Was a amusing video to watch though
Old Dec 20, 2005 | 03:57 PM
boon's Avatar
boon
Kev, I'll host them if you send them to me. PM me if you're interested mate.
