Fiesta Mk3 and 3.5 front arms???
been offered some zoo camber/castor adjustable front arms cheap from a mk3 frst will they fit ok onto a mk3.5 fiesta?
Or is it a no go?
Or is it a no go?
mk3.5 fiestas had 17mm balljoint whereas earlier mk3's had 17.5 mm balljoint, hence lower arm off early mk3 won't fit mk3.5 but mk3.5 arm will fit mk3 but be a complete piss fit and of little use.
hth
Tricky
hth
Tricky
