The Engines Out And The Verdict Is.....
Old Dec 19, 2005 | 06:33 PM
Steve__H's Avatar
Steve__H
Default The Engines Out And The Verdict Is.....
Knackered Rings, Bores With A Lip So Fat Mike Tyson Would Be Proud, And Some Worn Valve Guides
Looks Like A Rebore Is On The Cards, Along With 4 New Pistons, And A Set Of Rings
Going To Have The Head Skimmed And All The Valve Guides Done At The Same Time.
Turbo Looks To Have A Bit Of Movement In The Shaft, So Its off To ITS Turbos Tommorow For A Re-Build, And The Shell Is On A Trailer To The BodyShop For A Lick Of Paint
Should Be Back Together Mid Jan, But Will Be Posting Pics Throughout The Re-Build
Old Dec 19, 2005 | 07:03 PM
Kop2381's Avatar
Kop2381
Are you going low comp
Old Dec 19, 2005 | 07:21 PM
Steve__H's Avatar
Steve__H
Nope, Am Going Completely Standard, Want It To Last And Be Reliable
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
