What's involved when a car goes on a "jig"?
Old Dec 18, 2005 | 11:30 PM
RichardPON's Avatar
RichardPON
Default What's involved when a car goes on a "jig"?
You always hear about car's being "jigged" or being put on a "jig" after an accident.
Can anyone explain exactly what this means/entails?
Old Dec 18, 2005 | 11:32 PM
Alps Pacino's Avatar
Alps Pacino
I think they drill holes in the bent bit then attach the machine to the holes then fire the machine up to straighten it. Hydrolics i presume
Old Dec 18, 2005 | 11:33 PM
Cam's Avatar
Cam
the bodyshell is fixed to the jig (fitted with correct brackets for the shell) then hydraulic rams are used to pull the damaged shell straight.
Old Dec 18, 2005 | 11:34 PM
RichardPON's Avatar
RichardPON
Right.............
Car and chain it is then
Old Dec 18, 2005 | 11:36 PM
Cam's Avatar
Cam
Right.............
fookin cheapskate
Old Dec 18, 2005 | 11:37 PM
david's Avatar
david
Rich I use a ten ton porta power and the nearest solid objects that wont move for these situations, just mind and chock the wheels though
Old Dec 18, 2005 | 11:39 PM
RichardPON's Avatar
RichardPON
It depends how much the car has to be stripped down to be honest, as to whether it's worth the hassle.
The accident has knocked the front of one of the most forward chassis rails in towards the centre about an inch, but I need to move it back, and I can't see a hammer doing much good!
By the way Cam, just had a drive of Porkie's skyline - oh good lord, I want one!
Old Dec 18, 2005 | 11:41 PM
david's Avatar
david
That will come out no problem, plate it up though to get some strength back in if you can.
edited as my spelling is so shti
Old Dec 18, 2005 | 11:43 PM
RichardPON's Avatar
RichardPON
Plate it up?
You've got to be kidding - I couldn't weld if my life depended on it!
Old Dec 18, 2005 | 11:44 PM
Cam's Avatar
Cam
Hehe its funny how many people get converted after driving one.
If you hired a dozer (its big L frame with a hydraulic ram) that damage could be sorted with minimal stripping imo.
Old Dec 18, 2005 | 11:45 PM
RichardPON's Avatar
RichardPON
Well the crossmember unbolts easy enough, which I've done, but I'm tempted just to give it to a bodyshop and let them sort it.
Old Dec 18, 2005 | 11:49 PM
david's Avatar
david
Plate it up?
Get someone to then
Cam's Avatar
Cam
I cant see that repair costing a fortune and its best to leave it to a pro.
Old Dec 18, 2005 | 11:54 PM
philc's Avatar
philc
car, chain & lampost mate, then sell the motor
In all truth i cant see it being a fortune as cam mentioned, i still would get a few quotes though. Unless you know a trusted bodyshop.
Old Dec 19, 2005 | 01:15 AM
andyhardy's Avatar
andyhardy
A mate of mine worked on a farm, I've seen plenty GTE's and GSi's straightened by a fat ass John Deere and a large tree!
Seriously though - leave it to an expert, you'll only cry from the ribbing on here if you did it yourself and fucked it up!
Andy
Old Dec 19, 2005 | 01:38 AM
seeing as you acutally like to enjoy the handling of your car, get it on a jig where it can be got back into shape perfectly, you could get it very close with a porta power no doubt, but you just wont be able to measure exactly where it should be.
Only going to be a couple of hundred quid probably.
Ive had far worse damage than that jigged after learning that i cant left foot break as well as i beleived i could
Old Dec 19, 2005 | 08:06 AM
Mr RS500's Avatar
Mr RS500
I have jigged many cars in my time in the bodyshop trade
It isnt as expensive as you may think
You will be quoted about 1 hours labour to load the car onto the jig and 1 hour to take it off again ,
If the car cant be pulled back in about 8 hours worth of jig time then its usually not worth the repair anyway , so you probs will be looking at about Ł200 as a rough guide , as that looks a simple repair .
People worry about cars that have been JIGGED but if done correctly there is nothing to worry about as they are pulled back to within 1mm of what it was when new ,,,and you will find there is a 3mm tollerance in any brand new shell anyway so in fact it is within 2mm better than new
Paul
Old Dec 19, 2005 | 09:02 AM
RichardPON's Avatar
RichardPON
Paul,
That's the sort of thing I like to hear.
Also helps that what's been bent is just structural for the front of the car, and is only the most forward part of the front chassis rail......... and it's out about an inch or so.
Chip - shouldn't see that the handling is affected in any way, since the speed of the impact wasn't sufficient to push any damage back beyond the very front of the vehicle. All looks very straight underneath otherwise.
Having never had a car "jigged" before, is this something most bodyshops can do?
Old Dec 19, 2005 | 10:23 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
No not every body shop will have the room for a Jig..
I have a guy next to me who does just this all day long and does not charge much money at all! Might be worth givin him a call.
Old Dec 19, 2005 | 11:39 AM
jacko's Avatar
jacko
i have a jig at work quite a simple thing to use realy that damage is verry minnor and would be an easy repair
Old Dec 19, 2005 | 01:21 PM
RichardPON's Avatar
RichardPON
Cool, this is what I like to hear.
Always fear the worst when you start seeing twisted metal!
Shows & Track Days
Aug 26, 2015 05:11 AM
1cosworth
Aug 6, 2015 07:53 AM
Versus_Creations
24
Aug 5, 2015 09:32 PM
Aug 1, 2015 07:42 PM
