Focus RS toe in or toe out?
Old Dec 18, 2005 | 08:38 PM
alibongo's Avatar
alibongo
Default Focus RS toe in or toe out?
does anybody know front and rear tracking settings cos Mr Ford has not got data on his brand new £8k tracking gizmo??!!!!!! Is it best to run stock settings (if known ) or has anybody got a better set up?
Old Jan 20, 2006 | 10:59 PM
pete8tch's Avatar
pete8tch
here you go , may be a bit late tho.
anybody tried having a set up and did it work , my car seems to follow the road a lot even off the power , thought that was generally a tracking problem
Focus RS Geometry
Front Caster 2.98 Deg ---range 4.08 to 1.88
Front Camber 0.54 Deg ---range 0.77 to minus 1.85
Front Toe-in 0.15 Deg ---range plus/minus 0.25
Rear Camber minus 1.44--minus 0.12 to minus 2.76
Rear Toe-in 0.35 Deg ---range plus/minus 0.15
Old Jan 21, 2006 | 10:20 AM
Focus_RS1658's Avatar
Focus_RS1658
Ford TIS CD states the RS has the same tracking settings as all other normal Focus's...
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
