FAO... gearbox/clutch people...
Old Dec 18, 2005 | 06:32 PM
Sean_RS's Avatar
Sean_RS
Default FAO... gearbox/clutch people...
Was driving my FRST lat night... first of all it became difficult to put it in second gear... then it became really difficult to get in first and second... then setting off from traffic lights in 1st gear i went straight to 3rd because second was tough, as the revs started to build it just made a noise and the revs went high as if i was in neutral, i could put the car in 3rd, 4th and 5th but there was nothing there.... 1st gear was crunching going in as if i was crunching in to reverse, i had to limp home in second which was making a funny noise but it kept popping out and i had to hold it in. There didnt seem to be a problem eith reverse....
I'm just hoping that it is the clutch that has gone and not the gearbox as i was going to put in an APclutch soon anyway.
Any thoughts??
Old Dec 18, 2005 | 06:46 PM
ballin's Avatar
ballin
sounds like the box to me
Old Dec 18, 2005 | 07:14 PM
Sean_RS's Avatar
Sean_RS
Old Dec 18, 2005 | 07:19 PM
abdr500's Avatar
abdr500
its gear box fault if you hade to hold it into gear
Old Dec 18, 2005 | 07:24 PM
Sean_RS's Avatar
Sean_RS
Old Dec 18, 2005 | 07:25 PM
Butch.'s Avatar
Butch.
i would be 99% sure that the symptons u have given suggest that it is the gearbox that has gone.....
what sort of power u runnin?
As i work at JAMSPORT its a common thing to go on the fiestas and escorts as i seem to replace them quite often....
Manchester Mike's Avatar
Manchester Mike
maybe pm the gearbox man sean, i hope its not the box tho
Old Dec 18, 2005 | 07:29 PM
Sean_RS's Avatar
Sean_RS
its a MSD195... sounds like i may be paying the gearbox man a visit... anybody know his username?
Old Dec 18, 2005 | 07:36 PM
Butch.'s Avatar
Butch.
Would definately say its the gearbox if u want pricing up on gearbox, clutch or labour to remove and replace give jamsport dan a call on 01604 755529 im sure he'll help u out.
would advise fitting a good 4 paddle clutch kit and gettin the flywheel skimmed when u put the box back in aswell....
Old Dec 18, 2005 | 08:42 PM
Sean_RS's Avatar
Sean_RS
Cheers for the advice butch
not what i wanted to hear though
Old Dec 18, 2005 | 08:48 PM
Rick's Avatar
Rick
ballin's Avatar
ballin
www.gearboxman.co.uk
Old Dec 18, 2005 | 08:53 PM
Sean_RS's Avatar
Sean_RS
Thanks
Old Dec 19, 2005 | 10:01 AM
Sean_RS's Avatar
Sean_RS
Shit this is going to be painful.....
new cam CVH35 (stu..msd)
New gearbox (gearboxman)
New APclutch (Christian and Beccy i think)
= ŁŁŁŁŁ!!
Old Dec 19, 2005 | 11:08 AM
JamesH's Avatar
JamesH
Gear boxes are not cheap from Bernie, but that is not a bad thing at ll. Do it properly and do it once, call Bernie
Old Dec 19, 2005 | 12:15 PM
Sean_RS's Avatar
Sean_RS
Yeah looking at the price list i think ill stick to a stage 1 @ Ł475.
Nevermind it has to be done.
Old Dec 19, 2005 | 12:16 PM
Sean_RS's Avatar
Sean_RS
Bit of a wierd thing though that is sticking in my head is that when the car is turned off i can put it through the gears and it feels like it goes in, if it was goosed would it still do that?
Old Dec 19, 2005 | 12:23 PM
jayRS's Avatar
jayRS
yeah does sound like the main shaft bearing has given out.
its a weak point mate, my gearbox decided trho $hit it self years ago, had no warning, it just sounded real crap when i went home from a mates, by the time i got home it wouldnt even reverse! once stripped , main shaft was fooked, 2nd in input shaft had5 full teeth left, and the magnic wasw about a inch thick,
live and learn.
Old Dec 19, 2005 | 12:24 PM
Sean_RS's Avatar
Sean_RS
Nice...
Cheers for the input
yorkie92
Sep 6, 2015 05:34 PM
KW-rscos
Nov 27, 2013 07:05 PM
luke19790_3
Aug 15, 2012 06:15 PM
notSteveS2
175
Apr 12, 2007 06:38 PM
notSteveS2
Nov 24, 2006 01:12 PM
