clifford concept650 alarm
Which type of keyfobs do you get with the 650? Do they still give out both kinds (ie. the one with the four buttons with pictures on AND the five-button "master" keyfob")?
If you get the "master" keyfob, not sure if it's the same as the 600......if so, it's "shift" (the side button) twice, then key 3 (the bottom one, opposite the bigger button). Then it's key 4 to remote-start the car...
No idea with the "spare" keyfob, I've never ever used it...
no my key fob is different to that i have five buttons on the front and thats it!
one ofthe buttons says clifford on it
one is a star *
the other is two stars **
one is the boot release
and the other is to lock and unlock the doors
one is a star *
hello mate, not sure but have you had it set up when installed?? one of the lads had his alarm installed without engine finished and therefore remote start couldnt be set up! needs doing on the laptop, maybe using the cliffnet?
