OIL CAP BLOWIN OFF!!!
Old Dec 15, 2005 | 05:10 PM
stevedb's Avatar
stevedb
Default OIL CAP BLOWIN OFF!!!
hello people... can anyone tell me wot causes the oil cap to blow off??? its just started doin this and only does it when i drive it hard. i think it might be smokin more than usual or maybe im just bein paranoid.
Old Dec 15, 2005 | 05:38 PM
c8rwt's Avatar
c8rwt
too much pressure in the crankcase, its really really bad, my old xr3i did that and then 12 miles later the entire bottom end threw in the towel
Old Dec 15, 2005 | 06:36 PM
Oranoco's Avatar
Oranoco
Blow by on the piston rings. Go the same on my FRST which is why I'm doing a rebuild over the Winter.
Try a new oil cap and cleaning all the breathers out as a first port of call
Old Dec 15, 2005 | 07:07 PM
stevedb's Avatar
stevedb
that dosnt sound very good everytime i fix something another thing goes wrong. wot does a bottom end rebuild consist of??? good time to uprate a few parts then
Old Dec 15, 2005 | 07:44 PM
Oranoco's Avatar
Oranoco
Dunno as I've never done a standard one The one in my Escort was about the Ł2400 mark. I'm expecting the whole build on the FRST to be about the Ł2k area
Old Dec 16, 2005 | 09:34 AM
Scottish Greg's Avatar
Scottish Greg
Check your breather system before worrying about a bottom end re-build.
Old Dec 16, 2005 | 02:16 PM
weblefeck's Avatar
weblefeck
Yeah, i had problem oif Mayo, trying to blow cap off (screw in type) and dip stick out on my 1800 CVH sierra! It was cause i had a Piper-x filter fitted and numpty at garage hadn't done anything to sort out breathing!
I was shatting at first, thought rings had gone! Fixed it, did another 20k and still going strong (until some tit hit me)
D
Old Dec 16, 2005 | 07:17 PM
ballin's Avatar
ballin
what?!?!
Old Dec 16, 2005 | 08:13 PM
stevedb's Avatar
stevedb
im not very mechanical wot do u mean by sort the breather system out??? it must be workin cause theres oil where the end of the pipe sits. not a lot... that is normal i hope.
Old Dec 17, 2005 | 11:00 AM
boostaholic's Avatar
boostaholic
as scotish greg says clean all the breather pipes out and replace if needed they usualled cause excess crankcase pressure.check these first before thinking about a rebuild. good luck m8 hope it works its definately the cheaper option!
Old Dec 17, 2005 | 02:58 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
buy a haynes manual
clean the breather pipes as said (all the black pipes coming off the rocker)
i doubt its that tho the cvh does tend to get tired and worn around the 90 - 100k mark
Old Dec 17, 2005 | 03:31 PM
stevedb's Avatar
stevedb
cheers for the advice guys i dont think its the breather system. like i said before it seemed to be startin to smoke a bit aswell and its gettin worse.
Old Dec 22, 2005 | 09:00 PM
turbodaily's Avatar
turbodaily
they can smoke when breathers filled with gunk too mate, so go clean it out!!
Old Dec 22, 2005 | 09:10 PM
Oranoco's Avatar
Oranoco
The breather filter is still available from Ford and costs about Ł12 iirc
Old Dec 23, 2005 | 07:51 PM
pollocks's Avatar
pollocks
i had the oil cap blow off myne so i got a new one and then the dip stick keeps blowing out by a good 2 inch so i now have a replacement engine which will be put in asap and i can rebuild the engine thats currently in there to a nice reliable spec
Old Dec 23, 2005 | 09:00 PM
Sean_RS's Avatar
Sean_RS
Welcome to the world of ford... this week ive bought a bernie gearbox, kent cam and a new ap clutch, all because my gearbox decided to shit itself the other night.
Old Dec 27, 2005 | 10:38 AM
no grip's Avatar
no grip
common problem at higher revs - couple of zip ties to hold cap on and then fit a decent Bailey type breather system with catch tank etc - breathe to atmosphere don't try to recirculate the air
Old Dec 27, 2005 | 10:52 AM
Oranoco's Avatar
Oranoco
Zippying on the oil cap isn't curing the problem. It's a bodge. If changing the breather system doesn't cure the problem it is suffering with blow by on the rings. Only way to sort this is to change them
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
