header tank expanding
right only had my car two week and last week the headertank popped was squirting on to the exhaust manifold thourght it was on fire
any way i got a new header tank from ford and a cap as i thorght that it wasnt letting pressure out .fitted new 1s and the bottle is still expanding badly .
any1 else had this problem could it be the breather system not working very well ??????????
I was going to suggest replacing the cap as it may not have been holding pressure and allowing the coolant to boil, but as you have replaced it then i its eliminated that.
What does you temp gauge read?
A sticking thermostat could cause this and also a failed headgasket
Originally Posted by adamS2RST
Sounds like it's running ok, and fan kicking in and out is a good sign. As above, change the stat anyway and check for air leaks, bleed the system and see how you get on.
will change stat tomorrow see how it goes
