fao...anyone with rs 7 spokes fitted to a series 2
do they fit straight on with regards to the bolts/nuts or do you have to change anything on the hub , i.e do you use the standard escort bolts??
thanks
p.s the 17" ones
thanks
p.s the 17" ones
Originally Posted by swerv
hi gav , the missus has a mint series 2 , we will have to catch up sometime mate
When ya next goin to Scottys?
went sriaght on mine but i did have to space out the rears to clear my coil-overs ( will be fine with normal arrangement) you will more than likely have to get the arches rolled but try them on first you may be lucky
I have them on mine, (diamond cut ones) and had to use the collets that came with the wheel nuts cut them off and use on my standard bolts otherwise they are too small and almost pull through the wheel!
You will see what I mean when you go to fit them Apart from that, no probs at all, if the car is low then u will need to rol the arches really, mine scrubs a bit here and there. (providing they are 17's we are talking about? u haven't mentioned?)
Here are mine and Adam
Both look wicked, although mine are a little different as I've got the inserts pained black!
I've used gear bolts in mine, fit a treat,,,used to have the other ones, but fitted shodderly, so gear bolts are the way to go!!
Adam,,,know what ya mean huni about em pulling through
Go for gearbolts,,,,jobby done!!!
x x x
x x x
cheers guys , they are the painted 17" version as the car is used everyday i didnt want the diamond cut ones .
the arches are already rolled so they will go straight on
hopefully they will go stright on then
gav....not sure when im going up scottys next , when you going up there mate i might pop up...and yes still have the pimp wagon
Billy_RS
16
Oct 11, 2025 09:41 PM
Oct 9, 2015 07:38 PM
