had a new engine built with T34, Mahle Pistons, Gas flowed head with stainless comp valves, Kent Cam etc and mayb next year Cossie Management?? think I need new Injectors, wud u use standard Ford or any uprated one's that u cud recommend pse?!
If your going to cossie management you can use the standard yellows or more commonly greens, of course all depends on expected power and what your tuner suggests?
have decided to go 4 the standard injectors, car seems to be running sweet now, just have to wait till next year when i start to run her in. can't wait!!!
