EFI and CPS options ?
Ive got Everything i need from a FRST, Ecu, Complete inlet and throttle body,cross over pipe FRST head, management Loom ect, but my block hasnt got a CPS?
How can i get over this without takin out the engine to get it taped for the CPS, is there another option?
Cheers, Nick
Cheers, Nick
The FRST bottom end wasnt available as it had a big hole in it
Ive got everything else!
I wanted to use my bottom end as its not got many miles on it as it had a re-build a couple years ago,arps ect!
Im asuming i can just bolt on the FRST head, inlet ect to my s2 bottom end without the need for spacers ect?
Any ideas on the CPS then?
1.8 Sierra bottom pulley cover, alternator bracket (needs machining slightly), bottom pulley, alternator fan and the CPS itself.
You will need to drop the engine on the drivers side to get at it to change it and also extend the CPS wires
I'm not 100% on how much needs machining, didn't need to do it myself
