series 2 abs removal
Old Dec 9, 2005 | 03:08 PM
C2RST's Avatar
C2RST
Default series 2 abs removal
I am changing the box on my series 2 and would like to remove all the A.B.S whilst i am doing this. Can any1 give me any advice on how to do this? which brake lines etc?
Old Dec 9, 2005 | 04:45 PM
rs_daz's Avatar
rs_daz
This should help ya out
Old Dec 9, 2005 | 05:34 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
what about compensators?
Old Dec 9, 2005 | 05:56 PM
turbo.jon's Avatar
turbo.jon
You can do it without nige but it might lock the rears up if not u need use 1s off a 3i or similar
Old Dec 9, 2005 | 06:53 PM
1.9 xr2 on 40's
st170 breaking
yeah this is the problem, rather use inline than havin to piss about makin pipes to fit the ford jobbie if they are available, i have a set so mite be able to remove em from the braket i spose
dont wanna have it swapping ends
what did you get done jon?
Old Dec 9, 2005 | 10:41 PM
zippyobrien's Avatar
zippyobrien
ive got my abs removed and ive got xr3i 'compensator' valves and the master cylinder of a rs2000 (its got four outputs) car locks all four wheels and breakes are sweet (but a little bit numb feeling)
Old Dec 10, 2005 | 10:54 AM
C2RST's Avatar
C2RST
Default abs
cheers daz that woz exactly what i needed, top man. any advice on wot is the best servo and biggest master cylinder to use? If i can get the brake lines from fords for the non abs model they should fit straight in???? i would just need to block off a couple of places???? any tips???
tankybaby66
Feb 6, 2016 02:24 PM
AJC
Oct 8, 2015 11:09 AM
