biggest disc size on std 4 pot cossie calipers
Old Dec 9, 2005 | 02:10 PM
R4N SS's Avatar
R4N SS
Default biggest disc size on std 4 pot cossie calipers
need size for both front and rear.
if possible sizes of both 2wd and 4wd and price if anyone has it.
Old Dec 9, 2005 | 02:58 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i've got 330mm front discs on mine with modified std 4 pots with custom brackets and custom caliper spacers.
Old Dec 9, 2005 | 03:20 PM
R4N SS's Avatar
R4N SS
how did you modify the calipers - spacer?
R4N SS's Avatar
R4N SS
are yours 2wd or 4dr calipers and discs?
Old Dec 9, 2005 | 04:41 PM
Red16's Avatar
Red16
i assume by the title he has 2wd calpers, but dont go quoting me on that
Old Dec 9, 2005 | 05:19 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i've got 330mm discs on bells. i had to first make wider spacers between the caliper halves as the ap discs are thicker than standard venteds.
then i made a custom bracket to put the caliper further outboard from the hub carrier so that the pad area is centerd on the disc face.
then i modified the calipers to clear my 7 spoke wheels, but that may not be necessary on other 17" or bigger wheels.
am i right in thinking that you were at the last pf berkshire meet? being new there, i don't know everyone yet, and nobody introduced us and i'm a bit shy. if you come again, you can see them on my car. in the meantime, i might put it over the pit one day and get some photo's, if i do, i'll post them up for you.
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Thanasis
Sep 7, 2015 07:33 PM
rsturbo27
Sep 5, 2015 05:08 PM
cossirob
Sep 3, 2015 09:17 PM
