what spec to obtain 350-400bhp
Old Dec 8, 2005 | 09:52 PM
sygjim's Avatar
sygjim
Default what spec to obtain 350-400bhp
i have a sapp 4*4, with green, map, chip, kn, 3' exhaust line and t34 with .63 housing, and in few days a rs500 cooler
i suppose that i have between 300-330 bhp
i would like to know what mods i need to do to obtain 350-400 bhp with low budget
Old Dec 8, 2005 | 09:55 PM
Based on that spec.
A remap should see you over 350
Old Dec 8, 2005 | 09:58 PM
GUZZLER's Avatar
GUZZLER
if your on a low budget then don't stress your engine to much, or it may well stress your budget!
Old Dec 8, 2005 | 09:59 PM
ESCYSCOTT's Avatar
ESCYSCOTT
low comp pistons, WRC gasket, cams, greys/ light blues, little bit of head work + more boost should see 400bhp
Old Dec 8, 2005 | 10:03 PM
sygjim's Avatar
sygjim
next year, i will rebuild an engine with ported head
but, i can't have more than 350 with high comp and std cams?
Old Dec 8, 2005 | 10:45 PM
Smit's Avatar
Smit
The 60ft Launch King
Not very likey i'm afriad....
Maybe using higher RON fuel but not on the 98/99 RON stuff which is sold here.
**Edit noticed your are french** what RON fuel is sold in France?
Old Dec 8, 2005 | 11:00 PM
twitchyrear's Avatar
twitchyrear
as chip says a propa mapping session should see your car make good power ,might need to up to blues or greys to make the most of your spec if having a proper map done
Old Dec 9, 2005 | 05:21 AM
sygjim's Avatar
sygjim
hi, we have 95 for standard cars, and 98 for olders cars
i put 98 eveytime on my cossie
Old Dec 9, 2005 | 05:31 AM
sygjim's Avatar
sygjim
i am agree for the remap, but i need to do all mods before the remap, it s the reason of my question, i want to buy and fit all in few month, and planned a travel in your beautiful country
Old Dec 9, 2005 | 07:08 AM
Stu @ M Developments's Avatar
PassionFords Creator
Greys or bigger. Closed loop. Live map. 33peak 28 held.
Fast, reliable and economical Car.
Old Dec 9, 2005 | 07:15 AM
rs cos's Avatar
rs cos
Would he not need a new headgasket before he got to the end of your road stu? And maybe uprated fuel pump? Not havin a go just interested cause i'm thinking of gettin mine done with you
Old Dec 9, 2005 | 07:27 AM
sygjim's Avatar
sygjim
yes, i am agree with you
In fact, i have standard headgasket with strong and long stud, but i am not sure that it's the best solution
Old Dec 9, 2005 | 07:31 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
You have your block long studded but use a standard headgasket?
Old Dec 9, 2005 | 07:45 AM
sygjim's Avatar
sygjim
Yes, because i had planned to rebuild my engine next year, so, i didn't want to deposit the head
Somebody told me that is not a problem if the headgasket is in good condition
Old Dec 9, 2005 | 09:02 AM
sygjim's Avatar
sygjim
ok, and what mods when i will rebuild the engine ??
low comp piston or not ?
cams ?
breather system ?
Swirl pot ?
regards
Old Dec 9, 2005 | 09:06 AM
cams ?
breather system ?
Swirl pot ?
regards
depends where in that 350-400bhp range you are aiming.
For 350, you dont even need different injectors.
Old Dec 9, 2005 | 09:14 AM
sygjim's Avatar
sygjim
you know, we want always more power
so, the best for me would be between 350-400, so a middle 370 will be nice
Old Dec 9, 2005 | 09:25 AM
rscozzysie's Avatar
rscozzysie
carwise uk r building my engine at the mo.1000cc injector's ,t4, new chip,lowcomp little bit of head work.mine should see 380, 390 bhp.
can't wait.
bring on the drag strip next year
i just have to say they r a sound set off lad's.cheer's all at carwise
Old Dec 9, 2005 | 09:28 AM
can't wait.
sounds like a VERY conservative estimate on power?
is that at the wheels or something?
Old Dec 9, 2005 | 09:35 AM
rscozzysie's Avatar
rscozzysie
don't know. neil said it will b around the 380,390 mark.
i'll let everyone know when i get it rolled.
Old Dec 9, 2005 | 09:37 AM
Danielle's Avatar
Danielle
im not very good with cars lol but i think u need a swirl pot i dunno about anything else.......(reason i say this is cos i read in a magazine about a sapp 4x4 with 400bhp and i remember that bit lol!)
i also remember the person had an RS500 intercooler just like your getting and 0.63 exhaust housing, on i think a 2wd manifold.
wow ive impressed myself on what i remembered there is a bit more but i dont think it would be relevant to put down.
i was probably no help but still
rscozzysie's Avatar
rscozzysie
chip if that's at the wheel what would it b at the fly.
just out off interest.
cheers
Old Dec 9, 2005 | 09:39 AM
cheers
Getting up into the 500bhp ballpark mate.
Cant see why else you would need 1000cc injectors, and the T4 (depending on which variant it is) is good for 500bhp+ too.
Old Dec 9, 2005 | 09:43 AM
rscozzysie's Avatar
rscozzysie
fook me.cheer's mate
Old Dec 9, 2005 | 09:44 AM
Danielle's Avatar
Danielle
do you need a T4 to get 400/500 bhp to handle the pressure or something? sorry for the question i just wondered
Old Dec 9, 2005 | 09:51 AM
Its all about airflow.
To make 500bhp the engine needs to consume a lot of air, a smaller turbo wont flow enough air into the engine to allow it to do this.
If you were here, and naked, i could explain it a lot better TBH, why not pop round?
Old Dec 9, 2005 | 09:56 AM
Danielle's Avatar
Danielle
lol i think thats a good enough explanation x
Old Dec 12, 2005 | 05:00 PM
sygjim's Avatar
sygjim
ok, i think that i know what i want for the future
i will put some grey, so with my big t34, it will be fine.
Now, i need some advice about the engine:
- i will put a breathing system an a swirl pot
- i will rebuild my engine with ported head
but,
what headgasket i need to buy a group A or a multi layer ????
what piston i need to buy low comp or standard ????
i had read that i can keep my standard cam
i think that i will put closed loop and at the end make a live mapping
SO, do you think that i forget something
Thanks for your help
a picture of my actual motor
Old Dec 12, 2005 | 06:08 PM
B11GNS's Avatar
B11GNS
For that sort of power i'd keep the standard comp ratio
Old Dec 12, 2005 | 06:26 PM
sygjim's Avatar
sygjim
ok, you have the same spec that i want no ?
Old Dec 12, 2005 | 06:30 PM
B11GNS's Avatar
B11GNS
Yes its a very good spec that doesn't need the engine pulling apart and it drives nice too, its about 370-380bhp the boost peaks about 33psi and holds 28
Old Dec 12, 2005 | 06:31 PM
B11GNS's Avatar
B11GNS
and its very good on petrol too
Old Dec 12, 2005 | 06:33 PM
3drstretch's Avatar
3drstretch
B11GNS why have you had all that work done and fitted a diesel turbo.
Please change sig to a T34 not T35
Old Dec 12, 2005 | 06:37 PM
B11GNS's Avatar
B11GNS
Looks like its time for another 'is it called a 34 or a 35' discussion!
Old Dec 12, 2005 | 06:40 PM
B11GNS's Avatar
B11GNS
I always thought a T34 was an escort T35 with a .48 exhaust housing on and the T35 had the .63
Old Dec 12, 2005 | 06:43 PM
3drstretch's Avatar
3drstretch
Please see post by your chosen tuner on thread titled 'FAO turbo know it alls - UPDATED - its not magnetic'
Just joking ppl before you all get the hump.
Old Dec 12, 2005 | 06:46 PM
B11GNS's Avatar
B11GNS
Old Dec 12, 2005 | 07:07 PM
sygjim's Avatar
sygjim
my turbo, is a big t34
.63 housing and 76 inlet, not 70
and for the gasket, any ideaa
Old Dec 12, 2005 | 07:50 PM
B11GNS's Avatar
B11GNS
Mines got a grp A one but only because thats what was in there already, its probably ok but if i had to change one i'd go for a multi layer one
Old Dec 12, 2005 | 08:08 PM
sygjim's Avatar
sygjim
ok thanks
But there a big price difference, so, if the group A gasket is enough for my spec, i think that i will buy it
